Help CF-19 Driver XP
Discussion in 'Panasonic' started by vincentdali, Nov 28, 2009.
  1. vincentdali
    vincentdali Newbie
    Hi guys
    I'm new here, I need help buestra.
    I bought a Panasonic CF-19FDGAXCM think it is MK2.
    It came with Windows Vista, I've installed Windows XP SP3.Pero have a problem with the touchscreen driver.
    I download all the driver of the official page:
    http://pc-dl.panasonic.co.jp/cgi-bin/itn/toughbook/dl01.cgi
    And I have everything installed fine but when I install the touchscreen driver tells me that the system does not support these drivers.
    Some help.
    Thanks.
  2. Zippy-Man
    Zippy-Man Notebook Evangelist
    Your CF-19 is a digitizer model and not touchscreen that is why the drivers will not install.
    Take a look around the forums to read about digitizers. They require a special pen to be used with the screen and fingers will not work.
    -James
  3. vincentdali
    vincentdali Newbie
    Hello
    Thanks for the response, the special pen with the notebook I was coming, but do not have to use that driver to run it.
  4. Toyo
    Toyo Notebook Deity
    Please retype or translate that last post please.
  5. vincentdali
    vincentdali Newbie
    Sorry.
    The special pen I have.
    But I can not make it work.
    That driver is not used for this purpose.
    Thank
  6. vincentdali
    vincentdali Newbie
    I think I found the solution to my problem.
    After reading all afternoon forum, the problem is that I did not follow the process of installing the drivers.
    I'll start again and tell you.
    Thanks
  7. Toyo
    Toyo Notebook Deity
    I told you so! You gotta read and follow the order of driver installs to the letter. ;)
    Why do they make it so hard on us.....Good luck and let us know!
  8. vincentdali
    vincentdali Newbie
    Hello again.
    I spend a lot to be able to install Windows XP SP2 on my CF-19.
    After reading and reading this forum:
    Works do not get the screen with the pen:
    I have read this post, but no solution.
    http://forum.notebookreview.com/showthread.php?t=356620
    I'm desperate not to do.
    Any suggestions, thank you very much
  9. Toyo
    Toyo Notebook Deity
    I don't understand your question?
    Please allow me to express some words, they are not meant to be mean. Simply a suggestion for future help.
    When a new member comes on here and asks for help, and in return you recieve help from others, it is best and most appreciated to let others knoow how or what solved your problem. Sorry for the run on.......
    You will have much more success in the future with other problems. It is simply human nature. Please don't take offense to this, as you might not have known how it works around here:) Besides, over here in the ToughBook crowd we are a little different from the other embryos.:eek: :eek:
    Try to explain what it is you need help with on your last post again please.
  10. vincentdali
    vincentdali Newbie
    You are right, I'm new here and not how things work. I apologize.
    I state my problem:
    I have a panasonic CF-19FD with Windows Vista and everything worked fine.
    I try to install Windows XP SP2, I followed the manuals and installation order.
    I think I do everything right, but I am unable to make it work.
    Display rotation does not work, Screen digitizer not work.The other drivers work well.
    Thank you very much Toyo.
