HELP C0000135 %hs is missing
Discussion in 'Security and Anti-Virus Software' started by fi3re, Dec 2, 2010.
  1. Tacticious
    Tacticious Newbie
    I am very glad to see this problem solved. Kudos to the contributors here.
    I had this problem this morning, and upon starting it in safe mode realized AVG was causing the problem. I did a quick check on the forum to see how common this is... Wow! I can't believe AVG even exists, to be completely honest. How many low-level users are out there that have had AVG put on their computer by a tech-savvy friend/family member/co worker? This is ridiculous!
    On a sidenote, in W7 you get a great variety of tools built-in for troubleshooting. Hold F8 on the POST screen until you see your options, and hit Enter on the Repair option. You'll need to logon, but from there if you go into the Command Prompt, you can just rename the AVG folder and not hassle with downloading the AVG Repair tool. The commands are different in the Windows console than Linux (which threw me for a major loop), so here is what I used:
    cd /d C:
    cd Program Files (x86)
    rename avg poop
    You can replace poop with garbage or anything else. The original solution uses garbage, I use poop.
    Boot up computer, and follow instructions from original contributor on removing AVG.
    Not trying to hijack the solution, I give you 100% credit. Just thought I'd add my two cents, as I really didn't want to mess with downloading the AVG tools.
  2. RampageII
    RampageII Notebook Evangelist
    Well, not sure where I went wrong but I couldn't figure out how to do it using the method explained here.
    Instead, I ended up pulling the hard drive and mounting it on an external docking station so I could go inside and change the folder name. :D
    I was trying to use your method but I got stuck when you said
    "mnt
    sda# (usually 1 will be your windows partition)"
    I assumed "mnt sda#" meant select the "Mount" option which is suppose to Re-mount Windows Volumes.
    When I selected the Mount option, the system did perform an operation but then it just went back to the Main Menu screen shown on this link below (see 2nd pic on link)
    Main Menu Screen.
    I was expecting to see some Windows Volumes that I could select from, after selecting "Mount" option. But I didn't see anything. It just stayed in the same Main Menu screen.
    Since I got stuck there, I could not perform step two, which is;
    "2) Go to your Program Files(x86) and rename the AVG folder by hitting F6 while highlighting the folder and name it to "garbage" or something"
    What exactly did I miss? :confused:
  3. danyune
    danyune Notebook Evangelist
    Oh my bad I skipped a step lol sorry was too frustrated with AVG
    YOu go to Utilities-->File Manager
  4. Gil22
    Gil22 Newbie
    what does cd /d do?
  5. RampageII
    I see.
    So after Utilities-->File Manager, then go to step 2 right?
    Looks like several people were affected by this problem.
    So how did this AVG error happened?
    Was it an update error?
    I remember yesterday, before the problem, AVG performed an update automatically.
    I saw the "need to restart" window afterwards, by I postponed it because I was in the middle of something. Later on upon restart, I got the blue screen error.
    For a moment, I thought I was going to have to perform a clean OS. :eek:
    I'm glad I found this thread I few hours later. :)
  6. danyune
    Yeah then you should be able to browse your hard drive(s)
  7. cmasupra
    cmasupra Notebook Consultant
    How do I rename the AVG folder in Program Files (x86)? If I hit F6, I get a dialog box with the title "Move", and 2 teal/turquoise boxes in the dialog box, along with other options.
  8. DanielJackson
    DanielJackson Newbie
    Wow, thanks for the alternate Command Prompt method. I was trying to boot from disk but was having problems doing it with my flash drive. This thing gave me a headache all night, I'm glad to see it gone. Deffinetly going back to Avast. Thanks everyone!
  9. danyune
    When you hit F6, the "cursor" will default to the correct box. Just type a new name and hit enter and you're done
  10. cmasupra
    Neverind my question. I took a chance and just typed in "poop" in the second teal/turquoise box, and it worked. I have now uninstalled AVG and am running in Windows 7.
    Edit: I just saw your post right above this one, danyune. That's exactly what I did.
