HELP C0000135 %hs is missing
Discussion in 'Security and Anti-Virus Software' started by fi3re, Dec 2, 2010.
  1. fi3re
    fi3re Notebook Enthusiast
    AVG told me to restart my computer to install an update so i did...
    Now after a few moments of the starting windows loading screen (past alienware screen) theres a BSOD with the line
    STOP: C0000135 The program can't start because %hs is missing. Try resintalling the program
    and then restarts
    same issue in safe mode...
    Please help!
    M11x R2 i7 4gb
  2. fi3re
    Ok now i KNOW its avg.....
    paying attention to the last thing windows tries to load before failing during safe mode boot, AVGIDSEH.sys is the last thing before BSOD
  3. danyune
    danyune Notebook Evangelist
    Ok I had this problem too I just fixed it, I had no recovery image either
    1) Download the AVG Recovery CD at:
    Free Antivirus | Forum - How To Disable AVG When The Operating System Cannot Be Started Properly
    Once you boot up your PC off of the CD, select the first option. When the program loads go to
    Utilities --> File Manager
    from there go to
    mnt
    sda# (usually 1 will be your windows partition)
    2) Go to your Program Files(x86) and rename the AVG folder by hitting F6 while highlighting the folder and name it to "garbage" or something
    3) Restart your PC
    4) Once in windows, rename that "garbage" folder back to AVG
    5) Download the following removal tool program for your windows (32 or 64 bit)
    http://www.avg.com/us-en/download-tools
    6) Let the PC restart and all should be good
  4. danyune
    I'll be refreshing this page to make sure you got it and if you have questions
  5. fi3re
    oh sorry! i didnt know you responded!
    Well I was trying that except instead of renaming the program folder I was renaming the AVG system files in WINDOWS folder
    Now boot up crashes at Classpnp.sys......
  6. fi3re
    PROBLEM SOLVED! Used your method of renaming program folder.
    Undid changes to system files first so i could single out the problem...
    I guess its all just stupid AVG
    what should I do with the program now? Im really lost...should I update to a newer version? or just screw avg and uninstall it?
  7. Deks
    Deks Notebook Prophet
    If I was in your shoes, I'd simply replace it with MSE, Avira or Avast (all of which are better and lighter than AVG).
  8. danyune
    yeah it is 100% avg
    just renaming the folder fixes it
    a lot of people have trusted Avira from what I understand, should hit that program up
    I personally am just going to wait for AVG to fix
  9. kcwildguy
    kcwildguy Newbie
    Thanks everyone! I just corrected the same issue AVG hosed Windows 7, but the XP machine did the update fine. I am done with AVG, it is too bloated and I am tired of the constant "Upgrade" pop-ups from it anyway. I appreciate your help!
  10. Gil22
    Gil22 Newbie
    I love you guys, I was up all last night troubleshooting this exact same issue. I can't wait to get home and fix this puppy! This is the first problem i've had with AVG...i'll probably give them one more chance but just one!
