help: broke the ground prong off laptop charger
Discussion in 'Hardware Components and Aftermarket Upgrades' started by doger_666, Apr 14, 2008.
  1. doger_666
    doger_666 Notebook Enthusiast
    any way as the title says i broke the ground prong off my laptop charger, im just wondering what would happen if i used it with out the ground plug as there are chargers that dont even have ground plugs, would it make any difference if its there or not
  2. Lithus
    Lithus NBR Janitor
    You can potentially shock/kill yourself by touching the computer.
  3. doger_666
    now i do believe thats only if there is water or some thing like that around it or on you that that would happen. im just wondering if it can be used for a week or so till i can fix it
  4. Crimsonman
    Crimsonman Ex NBR member :cry:
    Considering it runs AC (alternating current) it's much closer to your heartbeat and will potentially be fatal and stop your heart.
  5. Lithus
    Lithus NBR Janitor
    Stick your finger into the power socket. I don't think you need water to feel a nice zap.
  6. doger_666
    its not like i would be touching any electrical parts on it well its running plus it does not have that ground when its running on the battery and we dont die every time are laptops run on there batterys or even get shocked XD
  7. Greg
    Greg Notebook Nobel Laureate
    Seriously...its a really bad idea to use an electrical part that is known to be broken. Stupid, too.
  8. doger_666
    its just the ground prong, every thing else is fine, and when the laptop is running on battery it does not have that grounding prong so i dont think there would be any really bad that would happen if its missing, heck ive used tons of power cords that have the ground missing, i just dont want any thing to happen to the laptop so im just checking, from what i learned in high school it was just to protect from shock incase there is water or some thing along those lines. also all the replacement chargers im seeing dont have grounds so how is it that they dont need a ground but this one would KILL ME if i used it
    not trying to fight any thing any one is saying im just used to people giving me the facts about things not just saying dont use it you will die, just right now im having trouble getting in touch with the people i normaly talk with about this kinda stuff
    also greg nice ultra portable, was thinking about the D430 but by the time i will be able to afford that it will probley almost be time for intel to bring out the next gen CPUs (witch im hoping will use less power)
    any way i will probley fix the cord on the laptop in like a week but my buddys so going to kill me if he cant use his laptop for a week
  9. TheGreatGrapeApe
    TheGreatGrapeApe Notebook Evangelist
    While it's not going to fry you in an instant unlike some of the posts suggest, Greg's statement is the general wise idea in such things, "Seriously...its a really bad idea to use an electrical part that is known to be broken.".
    Be it that it may harm you or harm your laptop, just get it fixed.
    If you have a GFCI outlet plug it into that if you must.
  10. hydra
    hydra Breaks Laptops
    See if you can replace your 3 wire with a 2 wire adapter like on HP, Dell and some others. I still see 3 wire(AC) adapters in use which is so third world engineering. If you have a house wiring ground problem or power strip problem, you could be at risk or pick up noise when sending audio out to receivers.
