(HELP) Annoying Problem! System > RAM : 4GB (2,99 GB usable)
Discussion in 'Gateway and eMachines' started by dwinandoy, Sep 5, 2010.
  1. dwinandoy
    dwinandoy Notebook Enthusiast
    guys please help me again.. i got this problem. in the system says 4GB(2,99 GB usable).
    its my Gateway P7805u, with 9800m GTS. I dont see anyone in this forum having the same prob wit me..
    im using win 7 ultimate x64. I use win 7 manager & tune up utilities.
    Ive had this problem before but stupidly i forgot how to recover the 1.01 GB. I knew it is one of the settings, whether in some tweaking softwares or windows' settings. I have solved a problem like this but i stupidly forget how to do it, one thing for sure is that the problem came from a software or windows' settings.
    In the resource monitor says 1030MB for 'hardware reserved'.
    Please anyone help me figure this out!!
    Thanks
    SOLVED!! :D:D:D by bios updating. I hope my problem will be a nice read for the other who maybe has the same problem :)
  2. atc9001
    atc9001 Notebook Consultant
    What laptop are you using? You likely dedicated 1gb of RAM to your onboard video, or your chipset can't handle more than 3GB of RAM
  3. dwinandoy
    @atc edited... please reply again. i think the chipset supports 4GB of RAM, since this problem just came up now and ive been using this laptop normally (4gb ram usable) for nearly 1 year..
  4. Hello_Moto
    Hello_Moto Notebook Evangelist
    try this:-
    msconfig>boot tab>advanced options>uncheck max. memory box
    might be currently set to 3GB which would account for your problem.
  5. dwinandoy
    @ hello moto, thanks. but i have tried that. Doesnt work :(
    I remember there is some settings saying that it will preserve 1 gb ram, or wont let ram less than 1gb. then when i disabled it, the whole 4gb came back. i just dont recall what setting was that..
  6. TANWare
    TANWare Just This Side of Senile
    System restore to a point before the issue cropped up?
  7. dwinandoy
    i turned off system restore. should i reinstall vista? or flash bios first? or what?
  8. TANWare
    I also have turned off system restore as I now have a SSD. What I do though is use the storage drive for windows back up and restore.
    If you boot to safe mode do you still have the memory reserved issue? if not a full removal of the video drivers and then reinstall may do the trick............
  9. dwinandoy
    @TANWare in safe mode, the issue is still there. so what should i do?
  10. dwinandoy
    i havfe reinstalled the Nvidia driver.. still doesnt work.. anyone???
  11. dwinandoy
    should a bios update be a solution???
  12. Ultimate Destruction
    Ultimate Destruction Notebook Evangelist
    Congrats. I guess the lesson here is that BIOSs can and do get corrupted?
  13. dwinandoy
    yup i think so. but its kinda weird since my mobo is new. my vga was shot and i sent it to gateway to change the mobo. they gave me this, motherboard with a corrupted BIOS :confused: :mad: , damn.. lucky its easy to fix lol :D
