Help after memory upgrade
Discussion in 'Hardware Components and Aftermarket Upgrades' started by magnetoeric, Dec 6, 2018.
  1. magnetoeric
    magnetoeric Notebook Enthusiast
    Greetings eveyone. My laptop is Nitro 5 AN515-52 with 8gb RAM and i recently added a new 8gb ballistix RAM https://www.amazon.in/Ballistix-Sin...d=1544105828&sr=8-1&keywords=ddr4+sodimm+2666
    I didn't face any issue so far and the memory is in dual channel. But CPU-Z is reporting DRAM frequency as ~1200MHz and cl 18. Can someone please tell me whether the maximum speed is indeed 2400 and not 2666 as i initially thought it would run at? Thanks in advance.
      File size:
      103 KB
      48
      File size:
      105.5 KB
      44
      File size:
      43.4 KB
      42
      File size:
      89.2 KB
      42
  2. ellalan
    ellalan Notebook Deity
    You have mixed different speed modules, when you install different speed RAM, the faster one downclocks to match the slower RAM.
  3. magnetoeric
    Yeah I know about that. But since the new RAM is XMP supported, shouln't it run at the maximum speed?
  4. Vistar Shook
    Vistar Shook Notebook Deity
    XMP or not, ellalan already answered the question. The faster RAM will default to the slower RAM settings, speed and timings.
    Using the new RAM by itself, your laptop might read the XMP profile or not, really depends on the BIOS but in most cases no it won't support XMP. If your BIOS has the memory configurations unlocked then it might be possible to manually set the speed and timings.
  5. magnetoeric
    Thanks for your reply. I'll try with the new stick alone and test whether it is running at the xmp profile :confused:
    Vistar Shook likes this.
  6. yrekabakery
    yrekabakery Notebook Virtuoso
    XMP is something that needs to be set manually, it won't automatically use the profile. If you don't have the option in BIOS, try XTU.
    magnetoeric likes this.
  7. senso
    senso Notebook Evangelist
    1200Mhz is the clock, because RAM uses Double Data Rate 1200Mhz = 2400MTs, aka 2400Mhz, its running like it should..
  8. magnetoeric
    You're right. I tested the new RAM alone but it still ran at 2400MHz. Thanks for the XTU suggestion, i'll try it. But before installing it, should i uninstall throttlestop? Because i heard both aren't compatible together.
    EDIT: I don't see any XMP related setting in XTU :(
