help about SSD
Discussion in 'MSI' started by Ivan994, Jan 11, 2019.
  1. Ivan994
    Ivan994 Notebook Consultant
    Hello,
    is there any way in bios to make my new SSD as primary OS SSD? I have installed win 10 on my new Samsung 970 EVO and formatted my old Toshiba SSD but still laptop on boot up shows that I have two OS installed and letting me choose. I know that I can solve this problem with removing old SSD, boot up os with a new one and then back in my old SSD but if I can solve this without opening my laptop again it will be great!
    Thank you!!
  2. senso
    senso Notebook Deity
    Use diskpart to delete everything(aka delete all partitions, and then make a single one spanning the whole disk size) from the old SSD, there is still a boot partition in there, thats why the BIOS thinks there are 2 OS's.
    Ivan994, Vasudev and Vistar Shook like this.
  3. zipperi
    zipperi Notebook Evangelist
    You can delete the boot entry for example with Visual BCD editor. But I'd keep the other entry for backup purposes - I do have a clone of my operating system in case of something goes wrong..
    Ivan994 and Vasudev like this.
  4. Vasudev
    Its better to disconnect/remove the old SSD and let BIOS reconfigure the Boot menu config. Once you verify there is only one entry called Windows Boot Manager then its done. You can plug back old drive.
    Ivan994 and c69k like this.
  5. Ivan994
    Thank you all guys. In the end I needed to disconnect old one and install again win 10 on the new one and put the old one back in the laptop. Now everything works ok. I just forget to disconnect my battery second time when I needed to back old one in the laptop o_O I hope that I did not burn anything. I had a problem just with one thing. I was not able to install chipset drivers, maybe because of new SSD. I install all the other drivers and then try again chipset one and it works but the log file is a bit strange to me. Could someone take a look please?
    Thank you all so much for help!
    [06DC:0530][2019-01-12T00:45:37]i001: Burn v3.10.0.1519, Windows v10.0 (Build 17763: Service Pack 0), path: C:\Users\Ivan\Downloads\Chipset_10.1.1.42_Public\10.1.1.42\SetupChipset.exe, cmdline: '-burn.unelevated BurnPipe.{B2F3EF56-43B5-46D2-9C07-4983B72DED17} {8DAA8EC5-5B95-46CE-B695-43DA0ECBDBAC} 9472 '
    [06DC:0530][2019-01-12T00:45:37]i000: Initializing string variable 'CHIPSET_PRODUCT_VERSION' to value '10.1.1.42'
    [06DC:0530][2019-01-12T00:45:37]i000: Initializing string variable 'INSTALLER_BUILD_VERSION' to value '3.1'
    [06DC:0530][2019-01-12T00:45:37]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx86.msi' to value ';NullDrivers.cab;NOT VersionNT64'
    [06DC:0530][2019-01-12T00:45:37]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx64.msi' to value ';NullDrivers.cab;VersionNT64'
    [06DC:0530][2019-01-12T00:45:37]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Ivan\AppData\Local\Temp\Intel\Logs\Chipset_20190112004537.log'
    [06DC:0530][2019-01-12T00:45:37]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Ivan\Downloads\Chipset_10.1.1.42_Public\10.1.1.42\SetupChipset.exe'
    [06DC:0530][2019-01-12T00:45:37]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Ivan\Downloads\Chipset_10.1.1.42_Public\10.1.1.42\'
    [06DC:0530][2019-01-12T00:45:37]i052: Condition 'VersionNT >= v6.1 OR (VersionNT = v6.0 AND NTProductType = 3)' evaluates to true.
    [06DC:0530][2019-01-12T00:45:37]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Chipset Device Software'
    [06DC:0530][2019-01-12T00:45:37]i000: Loading managed bootstrapper application.
    [06DC:0530][2019-01-12T00:45:37]i000: Creating BA thread to run asynchronously.
    [06DC:2584][2019-01-12T00:45:37]i000: ** MBA ** Command line:
    [06DC:2584][2019-01-12T00:45:37]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Chipset Device Software'
    [06DC:2584][2019-01-12T00:45:38]i000: ** MBA ** Calling Engine.Detect()
    [06DC:0530][2019-01-12T00:45:38]i100: Detect begin, 3 packages
    [06DC:0530][2019-01-12T00:45:38]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\NET Framework Setup\NDP\v3.5'
    [06DC:0530][2019-01-12T00:45:38]i000: Setting string variable 'DotNet40Client' to value '1'
    [06DC:0530][2019-01-12T00:45:38]i000: Setting string variable 'DotNet40Full' to value '1'
    [06DC:0530][2019-01-12T00:45:38]i000: Setting string variable 'DotNet45' to value '461814'
    [06DC:0530][2019-01-12T00:45:38]i052: Condition 'DotNet35 OR DotNet40Client OR DotNet40Full OR (DotNet45 >= 378389)' evaluates to true.
    [06DC:0530][2019-01-12T00:45:39]i101: Detected package: DotNet45, state: Present, cached: None
    [06DC:0530][2019-01-12T00:45:39]i101: Detected package: SetupChipsetx86.msi, state: Absent, cached: None
    [06DC:0530][2019-01-12T00:45:39]i104: Detected package: SetupChipsetx86.msi, feature: NullDriverFeature, state: Absent
    [06DC:0530][2019-01-12T00:45:39]i104: Detected package: SetupChipsetx86.msi, feature: PackageVersionFeature, state: Absent
    [06DC:0530][2019-01-12T00:45:39]i104: Detected package: SetupChipsetx86.msi, feature: LicenseAgreementFeature, state: Absent
    [06DC:0530][2019-01-12T00:45:39]i101: Detected package: SetupChipsetx64.msi, state: Absent, cached: None
    [06DC:0530][2019-01-12T00:45:39]i104: Detected package: SetupChipsetx64.msi, feature: NullDriverFeature, state: Absent
    [06DC:0530][2019-01-12T00:45:39]i104: Detected package: SetupChipsetx64.msi, feature: PackageVersionFeature, state: Absent
    [06DC:0530][2019-01-12T00:45:39]i104: Detected package: SetupChipsetx64.msi, feature: LicenseAgreementFeature, state: Absent
    [06DC:0530][2019-01-12T00:45:39]i199: Detect complete, result: 0x0
    [06DC:0530][2019-01-12T00:46:06]i200: Plan begin, 3 packages, action: Install
    [06DC:0530][2019-01-12T00:46:06]w321: Skipping dependency registration on package with no dependency providers: DotNet45
    [06DC:0530][2019-01-12T00:46:06]i052: Condition 'NOT VersionNT64' evaluates to false.
    [06DC:0530][2019-01-12T00:46:06]i204: Plan 3 msi features for package: SetupChipsetx86.msi
    [06DC:0530][2019-01-12T00:46:06]i203: Planned feature: NullDriverFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
    [06DC:0530][2019-01-12T00:46:06]i203: Planned feature: PackageVersionFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
    [06DC:0530][2019-01-12T00:46:06]i203: Planned feature: LicenseAgreementFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
    [06DC:0530][2019-01-12T00:46:06]i052: Condition 'VersionNT64' evaluates to true.
    [06DC:0530][2019-01-12T00:46:06]i204: Plan 3 msi features for package: SetupChipsetx64.msi
    [06DC:0530][2019-01-12T00:46:06]i000: Setting string variable 'WixBundleRollbackLog_SetupChipsetx64.msi' to value 'C:\Users\Ivan\AppData\Local\Temp\Intel\Logs\Chipset_20190112004537_000_SetupChipsetx64.msi_rollback.log'
    [06DC:0530][2019-01-12T00:46:06]i000: Setting string variable 'WixBundleLog_SetupChipsetx64.msi' to value 'C:\Users\Ivan\AppData\Local\Temp\Intel\Logs\Chipset_20190112004537_000_SetupChipsetx64.msi.log'
    [06DC:0530][2019-01-12T00:46:06]i201: Planned package: DotNet45, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [06DC:0530][2019-01-12T00:46:06]i201: Planned package: SetupChipsetx86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [06DC:0530][2019-01-12T00:46:06]i201: Planned package: SetupChipsetx64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
    [06DC:0530][2019-01-12T00:46:06]i299: Plan complete, result: 0x0
    [06DC:2584][2019-01-12T00:46:06]i000: Setting string variable 'IIF_MSI_SWITCHES' to value ''
    [06DC:2584][2019-01-12T00:46:06]i000: ** MBA ** Getting window handle.
    [06DC:2584][2019-01-12T00:46:06]i000: ** MBA ** Calling Engine.Apply(). Window handle: 198470
    [06DC:0530][2019-01-12T00:46:06]i300: Apply begin
    [2500:18E4][2019-01-12T00:46:06]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{49bc1e38-39b4-4728-9e75-cbe67ba9a329}, options: 0x7, disable resume: No
    [2500:18E4][2019-01-12T00:46:06]i000: Caching bundle from: 'C:\Users\Ivan\AppData\Local\Temp\{49bc1e38-39b4-4728-9e75-cbe67ba9a329}\.be\SetupChipset.exe' to: 'C:\ProgramData\Package Cache\{49bc1e38-39b4-4728-9e75-cbe67ba9a329}\SetupChipset.exe'
    [2500:18E4][2019-01-12T00:46:06]i320: Registering bundle dependency provider: {49bc1e38-39b4-4728-9e75-cbe67ba9a329}, version: 10.1.1.42
    [2500:18E4][2019-01-12T00:46:06]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{49bc1e38-39b4-4728-9e75-cbe67ba9a329}, resume: Active, restart initiated: No, disable resume: No
    [2500:22EC][2019-01-12T00:46:06]i305: Verified acquired payload: SetupChipsetx64.msi at path: C:\ProgramData\Package Cache\.unverified\SetupChipsetx64.msi, moving to: C:\ProgramData\Package Cache\{36A16AC6-68D4-44C3-B224-608601D6B353}v10.1.1.42\SetupChipsetx64.msi.
    [2500:22EC][2019-01-12T00:46:06]i305: Verified acquired payload: cab4FADBDD6DC6637E75E196F741A3F14D1 at path: C:\ProgramData\Package Cache\.unverified\cab4FADBDD6DC6637E75E196F741A3F14D1, moving to: C:\ProgramData\Package Cache\{36A16AC6-68D4-44C3-B224-608601D6B353}v10.1.1.42\media1.cab.
    [2500:18E4][2019-01-12T00:46:06]i323: Registering package dependency provider: {36A16AC6-68D4-44C3-B224-608601D6B353}, version: 10.1.1.42, package: SetupChipsetx64.msi
    [2500:18E4][2019-01-12T00:46:06]i301: Applying execute package: SetupChipsetx64.msi, action: Install, path: C:\ProgramData\Package Cache\{36A16AC6-68D4-44C3-B224-608601D6B353}v10.1.1.42\SetupChipsetx64.msi, arguments: ' MSIFASTINSTALL="7" IIF_MSI_SWITCHES="" ARPSYSTEMCOMPONENT="1"'
    [06DC:0530][2019-01-12T00:46:10]i319: Applied execute package: SetupChipsetx64.msi, result: 0x0, restart: None
    [2500:18E4][2019-01-12T00:46:10]i325: Registering dependency: {49bc1e38-39b4-4728-9e75-cbe67ba9a329} on package provider: {36A16AC6-68D4-44C3-B224-608601D6B353}, package: SetupChipsetx64.msi
    [2500:18E4][2019-01-12T00:46:10]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{49bc1e38-39b4-4728-9e75-cbe67ba9a329}, resume: ARP, restart: None, disable resume: No
    [2500:18E4][2019-01-12T00:46:10]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{49bc1e38-39b4-4728-9e75-cbe67ba9a329}, resume: ARP, restart initiated: No, disable resume: No
    [06DC:0530][2019-01-12T00:46:10]i000: ** MBA ** Apply complete. Status: '0' Restart: 'None' Result: 'None'
    [06DC:0530][2019-01-12T00:46:10]i399: Apply complete, result: 0x0, restart: None, ba requested restart: No
    Vasudev likes this.
  6. Vasudev
    If you have installed chipset drivers earlier then its not needed to install again because it doesn't add functions/features by updating to new version.
    Papusan and Ivan994 like this.
  7. Ivan994
    Thank you for an answer. I did not install earlier because it is failed to install. The screen was flickering many times and I need to cancel the installation progress but after I install all the drivers I managed to install chipset but with that log file. Is log file supposed to be like that?
  8. Vasudev
    Run driver store explorer in admin mode and see if there's intel chipset driver is installed or not https://github.com/lostindark/Drive...nload/v0.9.39/DriverStoreExplorer.v0.9.39.zip
    Ivan994 likes this.
  9. Ivan994
    Vasudev likes this.
  10. Vasudev
    Chipset drivers are installed properly.
    You can delete heci.inf with version 11.7.x. Its deprecated.
