Headset for 3.5 mm audio/mic combo jack? | NotebookReview
Discussion in 'Lenovo' started by not.sure, Mar 23, 2010.
  1. not.sure
    not.sure Notebook Evangelist
    Does anyone have a headset, or know of one, that can use the combo audio/mic jack on new ThinkPads?
    Most of these combo jack headsets are for cell phones and have a 2.5mm jack, and apparently no appropriate converters exist. I have a 3.5mm headset that came with my Nokia phone, but it's total garbage and useless.
    The official accessory headphones 57Y4488 seem to have separate jacks for audio and mic, too.
  2. lead_org
    lead_org Purveyor of Truth
    you can use the Iphone earphone. Ultimate Ear also produces one.
  3. pstrisik
    pstrisik Notebook Evangelist
    More useful would be an adapter that would allow use of any headset with separate mike and sound plugs.
  4. halobox
    halobox Notebook Deity
    The combo jack was a bonehead move in my opinion. Forcing everyone to USB headsets isn't cool.
  5. halobox
    Nearly all of the sound card makers make a sound card on a USB stick with mic and audio output jacks. For instance, see http://siig.com/ViewProduct.aspx?pn=CE-S00022-S1
    I also noticed Creative and other brands at Fry's.
  6. jonlumpkin
    jonlumpkin NBR Transmogrifier
    Or if you're really cheap ($3.13). I got My dad one of these for his old Latitude with a busted soundcard. Works well enough.
  7. bananaman
    bananaman Notebook Consultant
    For me the combo jack is brilliant. It doesn't force everyone to USB headsets. I already carry a 3.5mm phone headset with me anyway. Thanks to the iPhone, Blackberry, etc there is plenty of choice at all price and quality levels.
  8. aznguyphan
    aznguyphan Notebook Evangelist
    I agree, isn't the typical business user more likely to have a smartphone with its single jack headset or own a headset that needs both. It's consumers that buy the gaming headsets that would need both jacks.
  9. LennyOvo
    LennyOvo Notebook Enthusiast
    Hi everyone,
    Continuing from a discussion I posted on a different thread ...
    I've been looking for a headset adapter for converting the 4-pole 3.5mm combined headphone/mic jack to two 3.5mm stereo sockets for a standard stereo (audio in) headset. Yeah I want to use my existing headset! I don't want to use the internal mics for skype etc!
    The only one I found was here but am hoping to find an alternative, maybe a little cheaper. (EDIT: I just remembered this one too, but it's even more expensive with shipping).
    It is possible to make one yourself but would require soldering skills and patience, and would not look as good as a bought one. There is a guide here. The 3.5mm 4-pole plug and the two 3.5mm 3-pole sockets can all be bought from Maplin (UK) but again, the cost adds up (here and here)
    If only I could find one on ebay, I'm sure there would be one for £1 and free shipping (works for stuff like this!)... and there's not much that can go wrong with the headset adapter anyway.
    The suggestion in this thread seems to be to use a USB stick sound card.
    I don't like the idea of using a USB stick soundcard.... it just isn't an elegant solution IMHO.... why fill up a USB port simply to use headphones when a headphone socket exists for that purpose? An audio-only solution is more elegant and *should* work out cheaper (it's just the plug/sockets and some cables).
    Thanks
    LennyOvo
  10. Mutnat
    Mutnat Notebook Consultant
    I have to agree. Thanks for posting the links to those two adapters. I have tried to do some google searching for something like that a couple of times and came up with nothing. I figured the product(s) existed, I just didn't know how to find them. I will eventually pick up an adapter like one of the two you linked. :)
