hdd rubber rails and ssd spacers for w530
Discussion in 'Lenovo' started by clone768, Dec 8, 2018.
  1. clone768
    clone768 Notebook Enthusiast
    For my w530, I am getting a 9,5mm high hdd, to replace the 7mm high hdd the notebook came with.
    Do I need different rubber rails now :vbconfused:
    Also, the w530 hardware maintenance manual, says rubber rails for hdd, but spacers for ssd. What's the difference between the two?
  2. JehutyZeroshift
    JehutyZeroshift Notebook Evangelist
    Hello clone768, I bought a second hand W530 three days ago and I happened to bump into the same problem as yours. Mine came with the stock 256GB 7mm Samsung SSD with the plastic spacers on it. I think those spacers are really intended for SSDs because it doesn't need any form of shock absorption unlike HDDs.
    Regarding the 9.5mm and 7mm variants of the HDD rubber rails, I was able to find this discussion on the Lenovo forum helpful: https://forums.lenovo.com/t5/ThinkP...will-work-in-my-T-seriesThinkPad/ta-p/1047969
    I was able to find on eBay a seller from Hong Kong selling a kit including the 9.5mm rubber rails and the caddy/tray that would enable fitting a 9.5mm HDD on a W530: https://www.ebay.com/itm/New-for-Le...rd-Drive-Caddy-Rail-Screws-9-5MM/182026809110
    I'm planning to buy that soon as I'm planning to fit an old 9.5mm Seagate HDD on the primary disk slot of my W530.
  3. clone768
    Thanks a lot, and sorry for my delayed reply. Have in mind that you can also use some rubber material and make your own, which is what i did with an hdd in the ultrabay.
  4. JehutyZeroshift
    Oh it seems like you McGuyvered it :) On my case I'll be buying the ones on Ebay as I lack the metal caddy that's needed for HDD drives in the primary HDD bay. As long as you'll not be using it on the go rugged style, I think a DIY approach would work.
Similar Threads - rubber rails spacers
  1. donotwant
    682
