Has anyone figured out turn-by-turn road navigation using the Toughbook GPS?
Discussion in 'Panasonic' started by EdFromBJCS, Aug 14, 2019.
  1. EdFromBJCS
    EdFromBJCS Notebook Geek
  2. toughasnails
    Thank you very much for this. Very well written up. This is going to help a lot of members. :vbthumbsup:
    UNCNDL1 likes this.
  3. interestingfellow
    interestingfellow Notebook Deity
    TLDR
    Windows 10 doesn't update NMEA fast enough for the win 10 Maps app and this link shows you how to fix that?
    Primes and toughasnails like this.
  4. Dr. Trout
    Dr. Trout Notebook Enthusiast
    TRY...
    "HERE WE GO"
    BEST ONLINE OFFLINE GPS MAP
    APP IVE SEEN ANYWHERE
    AND ITS FREE
  5. BaRRmaley
    BaRRmaley Notebook Deity
    And it's for android and ios only.
    r.wyll, UNCNDL1 and toughasnails like this.
  6. toughasnails
  7. BaRRmaley
    I'm sure it's a bad idea to use emulators when you are going to routes without mobile Internet.
    Re usage of this software under Android - I've just tried it and I see that offline map of Ukraine is 1.3GB while iGO map (HERE Q2 2019) is 173MB. I would say "no" :)
  8. CF30Medic
    CF30Medic Notebook Enthusiast
    Get a copy of Streets and Trips 2013 off eBay. Works like a charm
    No. Windows10 needs help finding the GPS receiver in the toughbook. His instructions help you help the Windows 10 maps app connect to the gps. It’s a good write up if you want to use the maps app...which is pretty good, and free.
    toughasnails and UNCNDL1 like this.
  9. kschewe
    kschewe Notebook Geek
    I been down this road and I will say now windows just plain sucks at navigation for offline. Android is king. You can try running emulators or even android x86 or bliss on your toughbook. They work and can install here or mapsme I have but the issue is there is no support for gps yet. That will come soon i hope.
    There is a good one i use all the time for linux called foxtrotgps for more off road stuff.
  10. Kerozin
    Kerozin Notebook Enthusiast
    Only proper way (that I know of) to get turn-by-turn navi on Windows is Garmin Mobile PC software, it works exactly the same as older dedicated Nuvi models, has the same UI and uses official Garmin maps.
    Works nicely on CF-19 and CF-C1, touch screen and all.
