Hard drive question - customizing
Discussion in 'HP' started by weiser701, Dec 4, 2006.
  1. weiser701
    weiser701 Notebook Consultant
    When these are my options (for dv6000t through Costco):
    FREE Upgrade from 40GB 5400RPM to 80GB 5400RPM [included]
    40GB 5400RPM SATA Hard Drive [$0.00]
    60GB 5400RPM SATA Hard Drive [$0.00]
    100GB 5400RPM SATA Hard Drive [add $48.00]
    120GB 5400RPM SATA Hard Drive [add $92.00]
    160GB 5400RPM SATA Hard Drive [add $162.00]
    Are the 40GB and 80GB HDD's in bold not SATA? This always had me confused. If they aren't, what type are they?
  2. miner
    miner Notebook Nobel Laureate
    They are. Otherwise they would have had to use a different motherboard just for those 2 drives which is very unlikely. The only probable reason why they dont mention it is due to space constraints in the webpage.
  3. weiser701
    actually, that's what i was thinking. i don't know much about what you said in the first sentence, but it all seems very logical. i think i'll go ahead and save the $50 by going with the free upgrade to 80GB over the 100GB. will upgrading to 7200RPM be an option in the future? if so, the free 80GB HDD will be fine for now. thanks for the feedback
  4. jetstar
    jetstar Notebook Deity
    Upgrading the hard disk drive is a fairly simple process, which can be done by most people.
  5. weiser701
    cool. thanks a lot guys!
  6. WeAreNotAlone
    WeAreNotAlone Notebook Deity
    miner was saying for a mfg to use two motherboards would be stupid. It would cause all kinds of support, parts supply issues, Plus hard feelings from customers would bought thinking they were getting a SATA drive and didn't.
    While on some models they DO use differant motherboards, it's because of differant GPU's used (the video card) as the GPU is integrated into the model board (built-in) on 99.9999% of units being currently produced.
    You can check for such, check to see what parts fit your machine here:
    HP PartSurfer
    http://www.partsurfer.hp.com/cgi-bin/spi/main
    :D
