hard drive moving, solution?
Discussion in 'VAIO / Sony' started by KeithF40, Jul 8, 2011.
  1. KeithF40
    KeithF40 Notebook Consultant
    I have a sony netbook and I had to replace the hard drive. Anyway long story short the hard drive moves a little bit. I can put something on the side of it so that it doesn't move(disconnect). Not exactly sure what kind of material to use so that I do it safely. Need something about half an inch thick, any suggestions?
  2. arth1
    arth1 a҉r҉t҉h
    I would use a bracket that screws into the drive.
  3. TofuTurkey
    TofuTurkey Married a Champagne Mango
    I use a piece of soft rubber, the kind used to erase pencil marks. These can be cut easily to fit.
  4. KeithF40
    prob use the second solution until i get myself some brackets. thanks guys.
  5. beaups
    beaups New Jack Hustler
    ^Why can't you use the bracket that was on the drive you removed??
  6. KeithF40
    I lost it. What should I be searching for on ebay for a replacement?
  7. beaups
  8. KeithF40
    Ill give them a call, just hoping they dont jack the prices up too much, sometimes they do
  9. irishsumo
    irishsumo Notebook Consultant
    Anything that holds it in place and absorbs vibration will do really - I had an old TR with a spare HDD replacing the optical drive, held in place by electrical tape and and some foam mesh that the hard drive came in folded over to absorb the vibrations from the case around the optical drive. Lasted a trip around the world! Took care to not block that hole they said not to block and to make sure it was held in place from both horizontal axes so it couldn't slip.
    Edit: spelling mistake on "block"
