[Guide] Upgrading P150HM with 2960XM....and overclocking it!
Discussion in 'Sager and Clevo' started by jaybee83, Jan 18, 2013.
  1. Meaker@Sager
    Ah the power of PMs ^-^ What system are you running?
  2. derekdauzat
    derekdauzat Notebook Enthusiast
    i have MALIBAL lotus p150hm flashed p170hm, 8gb ddr3 samsung, gtx 485m, got 2920xm had 2670qm (force 3 ssd 128gb) i love the ssd .. .. bios mod 80-70-32s, .. what should i do next? any other cools mods, maybe gpu,, any guidance on xtu..
  3. beemerboy88
    beemerboy88 Notebook Enthusiast
    Xm only clocked to 4.4 (bsod at 4.6ghz). Stock bios. 240w Psu modded by de-soldering and putting in clevo cable from 180w psu. Tested with multimeter and no loose connections. Only cuts out when gpu is on max load. Cpu benchmarks/stress tests work ok.
    Sent from my GT-I9300 using Tapatalk 2
  4. derekdauzat
    i got one of these x75 power connector 7.4 x 5.08 female jack to 5.5x2.5mm male..
    anyone else has one and can coment on how it worked out
  5. Meaker@Sager
    That cable should work, what was your original GPU?
  6. derekdauzat
    560m then i got 485m was cheap $200 the cpu was 2670qm now 2920xm
  7. Meaker@Sager
    The 560M HM mobo might have been rated for a bit less than the higher ones. It's not something I have checked but have seen it in other models from other companies.
  8. beemerboy88
    not changed gpu. laptop came with gtx 580m. only upgraded from 2760qm to 2960xm.
  9. Mr Najsman
    Mr Najsman Notebook Deity
    If I buy a 2960XM, for example: INTEL i7 2960XM 2.7GHz processor QS For 65 chipset CPU upgrade monkey | eBay
    Will that one work in my P150HM? Can I skip the flash if I dont want to oc, just plug it in?
    Will the 180W psu be enough for a stock 2960XM and a 780m with only mild oc?
    Related: Can I fully utilize a 780m or similar if I keep my 2670QM? Im already cpu-bound in Planetside 2 90% of the time.
  10. jaybee83
    jaybee83 Biotech-Doc
    first of all, well have to wait and see if the 780m could even work in our hm laptops ;)
    as for ur other questions: if u dont plan to oc ur new cpu, its just plug n play and ure good to go :) be aware tho that ES and QS samples may often get hotter and less stable than their oem production counterparts. so maybe it would be best to wait a bit and see if a good offer pops up on ebay or here in the nbr marketplace :)
    in theory, the 780m (122w) combined with the 2960xm (55w) would already be pushing the stock 180w psu and u may in some cases get throttling due to not having enough power. htwingnuts review showed that the 180w psu is already close to its limit using a non-xm cpu, so with the combo u have in mind there most likely wont be any headroom left for ocing whatsoever and u might even be restricted at stock clocks already. best thing to do then would be to politely ask meaker or someone else proficient enough to mod a dell 240w psu for you ;)
    Sent from my Galaxy Nexus using Tapatalk 2
