Guide to disassembling the G53JW and installing second hard drive
Discussion in 'ASUS Gaming Notebook Forum' started by bendok, Nov 16, 2010.
  1. Donald@zTecpc
    Donald@zTecpc Company Representative
    The ASUS G73J caddies do not fit the G53J properly. Notice also the caddies do not come with the necessary screws.
  2. Networc
    Networc Notebook Consultant
    When you say that it doesn't fit properly, do you mean that it doesn't work at all in the G53?
    I'm not trying to be irritating, it's just that I have both a G53JW-XA1 and an Intel SSD in the mail and I'm hoping to do the install once and be done. (fingers crossed)
    Thanks for the help.
  3. Donald@zTecpc
    If you have a hammer, pliers and a saw, plus the screws, you might get it to work, but the tabs to secure it are in a different place on the ASUS G53JW, so you might as well use duct tape, velcro strips and a little bubble gum. :)
  4. Chastity
    Don't tell them to use bubblegum, cuz they will... :p
  5. DCx
    DCx Banned!
    Does bubble gum void my warranty?
    o_O
    ... jk.
  6. Networc
    I was able to find an ebay listing for the G73 bracket depicting it installed in the G53:
    If the correct screw for that gap is an M2.5x5, would something longer (eg: M2.5x10) work with a spacer? Is a spacer of that size common?
    ...Perhaps some gum would work?? :rolleyes:
  7. Donald@zTecpc
    Using a longer screw with a spacer will impede putting the bottom cover back on.
    If it fits...wear it. But if it doesn't fit...it doesn't fit :(
  8. toyota_scion_tc
    toyota_scion_tc Notebook Consultant
    I had to bend the tabs down to a 45 degree angle on one and 30 on the other. I dont like it so I ordered the right caddy from Asusparts this was before my G53 Crashed :(
  9. Networc
    I PM'ed Brian@ASUS on the ROG forums and he said the estore should have 82x G53 caddies in stock; however, I don't see them.
    I sent a message to the estore about it. For now, I'll probably just go with cardboard.
    And gum.
  10. rparrado
    rparrado Newbie
    16 GB RAM is for Virtual machines.
    Gamers laptops is used for demos with hyper-v, vmware, virtualbox etc...
    I need a demo for exchange 2010 with tolerance to fail and a blade no is an option for carry in my bag....
    I need change the memory to 16 GB for this,
    someone has been successful and been able to find the fourth memory bank?
    Anyone? :(
