Guide to disassembling the G53JW and installing second hard drive
Discussion in 'ASUS Gaming Notebook Forum' started by bendok, Nov 16, 2010.
  1. pooohbear
    pooohbear Notebook Enthusiast
    did anyone notice a yellow ribbon over the connection to the touchpad when doing this ?
  2. toyota_scion_tc
    toyota_scion_tc Notebook Consultant
    A lot of laptops have colored tape over connections. I am not exactly sure why. It could be used as a tamper type seal to see if you tampered with it. I have no clue. I had an Alienware with orange tape over a ribbon area and a Dell with green tape.
  3. mk1freak
    mk1freak Notebook Evangelist
    just wondering if someone can post up the part number for the second hard drive caddy? trying to find one or least find the specs of it to match it.
    Thanks in advance!
  4. toyota_scion_tc
    P/N 13GN0Z1AM060-1 that www.asusparts.eu has on its site.
  5. mk1freak
    wouldn't let me connect to database :/
    i was able to find that part number on a german site but alas i dont read it, using babelfish it looks like it may only be the primary hdd caddy.
    i got an email back from an e-store rep(north america), apparently they aren't selling the secondary HDD bracket as of yet, but they will be updating their e-store catalog soon, so who knows, i'll keep looking
  6. toyota_scion_tc
    There is no difference in the HDD bracket, depending on what side you use change the mounting holes. One bracket for either side.
  7. mk1freak
    you are correct, when i tried it on the other side it, i mistakenly mounted it using the primary HDD side mounting holes >_<
    now i just need to find one :/
  8. Cetan
    Cetan Newbie
    So is getting to the fourth hidden RAM slot a huge PITA, or is it a lot easier than it's sounding?
  9. Chastity
    No, it's a PITA. You'll have to open her up to get the top panel off to get to it.
  10. Networc
    Networc Notebook Consultant
    Brian@ASUS posted a sticky that HDD caddies are now available; however, the e-store only lists a caddy for the G73.
    Does anyone know if the G73 caddy works in the G53? It looks similar to the pictures posted by bendok.
    Also, bendok's pictures depict what look to be rubber strips for shock absorption, but I can't quite tell from the e-store photos if they're on the caddies.
