Guide to disassembling the G53JW and installing second hard drive
Discussion in 'ASUS Gaming Notebook Forum' started by bendok, Nov 16, 2010.
  1. myHostie
    myHostie Notebook Guru
    You do need to remove the screw above the bottom right screw at #7 to unlock the back panel. Otherwise, the back panel will not come off.
  2. j00zl33t
    j00zl33t Notebook Consultant
    Wow awesome tutorial! Good job bendok!!
    I do have a question though...so prior to doing all this i know i need to burn a win7 DVD. Does it have to be a boot DVD or just burn the iso regularly?
    Also, how many times can I do a fresh OS install using the same CD key? I heard somewhere that once you delete the stock OS install, you're screwed and next time you do an install of windows 'anything', you have to provide a new key..any truth to this?
  3. KaFOFO
    KaFOFO Newbie
    I would also like to know the answer to this.
    Bendok, did you have any problems activating windows 7 on your new SSD with the windows 7 product key provided on your laptop?
    Thanks to anyone who could provide an answer and sorry for a noob-ish question.
  4. Bloodstriker
    Bloodstriker Notebook Enthusiast
    I currently have the A1 version, which comes with 6GB RAM, and I just ordered 1 SODIMM of 4GB 1333. I think the specs state that 8GB is the max (d'oh!!!).
    Will the 4GB still work in the slot and the system will only address 8GB instead of 10GB? Or will I have to either replace the 4GB with a 2GB, or will I be able to remove one of the existing 2GB and have the new 4GB installed?
  5. Donald@zTecpc
    Donald@zTecpc Company Representative
    Just install the 4GB in the slot under the keyboard and it will recognize 10GB.
    The G series ASUS laptops actually support 16GB total memory, even though the specs say 8GB.
  6. myx
    myx Notebook Deity
    The i7 version supports 16gb, the i5 only 8 :)
  7. toyota_scion_tc
    toyota_scion_tc Notebook Consultant
    How do you access the 4th memory chip? I know where its located now but cant figure out how to get to it.
    I called Asus and they told me 8Gb only. I read in a few places 16Gb. Can anyone verify if this is true? Also is our memory triple channel compatible or only dual channel?
  8. Donald@zTecpc
    ASUS was reading from their specifications. the ASUS G53JW-A1 will support 16GB DDR3/1333. Since it is using 4 pieces it will not support triple channel, but dual and triple channel is 92% marketing fluff and 8% real performance improvement...not enough real world performance increase to even notice.
  9. toyota_scion_tc
    next question I have had my computer appart, how the heck do you get to the one memory slot underneath the key board that is hidden under the sheet metal? I have seen three of the four slots. Kingston even shows 8Gb max.
  10. Sigtyr
    Sigtyr Notebook Enthusiast
    I think someone mentioned that it's under that black plastic in the middle, I'm not sure.
