Guide: Samsung Recovery Solution 6 (SRS6) and Windows 10
Discussion in 'Samsung' started by Gulfmaster, Aug 30, 2015.
  1. Tisusbr
    Tisusbr Newbie
    The admin tool for 7.2 is all in your 7.2 recovery download, however quite tricky to extract.
    Here is what I did to get a working SRS 7.2 Admin tool:
    Prerequisite: A bootable WinPE5 environment (can use the one from SRS6)
    1. Extract BASW-A0419A09 to an empty directory of your choice. This will also extract the needed WIM file SRS7_2WinPEx64.wim (in BASW-A0419A09\Recovery\UpdateWinPE).
    Unfortunately you cannot mount this with DISM, so you will need WIMLIB instead.
    2. Download WIMLIB (http://wimlib.net/downloads/wimlib-1.8.2-windows-x86_64-bin.zip)
    3. Using wimextract extract the contents with SRS7_2WinPEx64.wim (image 1) to an empty directory of your choice
    4. Mount the bootable WinPE5 environment to a logical drive letter (diskpart -> select volume -> assign letter [WinPE-Letter])
    5. replace [WinPE-Letter]:\source\boot.wim file with the boot.wim from the extract of step 3 (make sure you keep a backup of the original boot.wim)
    6. copy the extracted \Recovery folder (see step 3) to [WinPE]\ (root)
    7. Boot your WinPE recovery environment. It will now boot into SRS 7.2
    8. In the recovery console open the admin tools: Press 'Ctrl-Shift-F10', Password is 'SECOS'
    9. You can now create your SRS 7.2 admin USB stick.
    To restore the original WinPE environment:
    1. Restore boot.wim from backup (step 5)
    2. Delete \Recovery folder
    Please realized this whole crazy process. But when I try to realize the admin USB stick creation. He leaves not select the pendriver. He always leaves as the standard pendriver that held the boot recovery. Disallowing I realize the creation of admin USB stick. It is the question. How do I select the pendriver for me to realize the creation. ?
  2. dosibox
    dosibox Newbie
    Yes, you're right until here and now : AdminTool_for_SRS6.iso\WinClon\AdminTool.exe\Click on "Run" button :
    on STEP 1 : Install Recovery
    then
    STEP 2 : Finalize Recovery Setting
    then
    STEP 3 : Initial Backup
    Done !
    Don't press 'F4' at start up !
  3. Khaja
    Khaja Notebook Enthusiast
    @Gulfmaster
    I have followed the steps given in the post but I m not able to proceed with the step 3 why I ran the srs6 to take initial Image.. System getting re started without taking the image backup. However F4 to recovery is also not working.
    Installed win 10 on my pc[​IMG][​IMG][​IMG][​IMG][​IMG]
    Below is the image from recovery application where i m not able to see the reoccery partition or backup initial factory image option[​IMG]
  4. Gulfmaster
    Gulfmaster Notebook Guru
    Hi, I'm assuming that you have fastboot and secure boot disabled.
    Did you run the settings.exe file with administrator privileges?
    What version of recovery are you using? It should be 6.1.0.1
  5. Khaja
    Yes, i have executed the RecoverySettingsSV.exe with administrator priviliges only.. Still have the same problem
  6. Gulfmaster
    Great, what version of recovery?
  7. Khaja
    I m not sure of the version. However i have tried with the sw which u havw provided in this postt
  8. Gulfmaster
    Run Samsung update and update to the latest version.
    Then run admintool.exe and start from there.
  9. Khaja
    Let me try noww.
    Update:
    If i start from 1st step after updation of recovery software, system temoving the exisitng installed sw and installing the old one based on the admintool.
    If i try from second step, recovery sw do not show me option to back up as shown below[​IMG]
    Please help
  10. Gulfmaster
    for the initial backup, you have to use v6.1.0.1.
    Did you continue to run step 1 and try the process?
    If that didn't work, try creating a new USB admintool after getting v6.1.0.1 and try the steps again.
    Please let me know what the outcome is. thanks!
    Once your initial backup is done, you may rollback to the previous version to take regular backups.
    Dannemand likes this.
  11. Khaja
    I have tried to run step 1 with v6.1.0.1 then it does the samething means its keep on restarting.
    What is meant by creating new usb admin tool after getting v6.1.0.1 ? It ll b great if you can share the zip.
