Guide: Samsung Recovery Solution 6 (SRS6) and Windows 10
Discussion in 'Samsung' started by Gulfmaster, Aug 30, 2015.
  1. Khaja
    Khaja Notebook Enthusiast
    I have started again from step 1 and added the screen shots below..
    Guess, i have to install windows in windows partition itself...
    [​IMG][​IMG]
    I have installed the recovery which i have downloaded from the post and started from step 2
    Executed the file with admin rights and below happens.. PLease check if any command is missing in this step...
    No luck. Its just getting restarted... F4 link is not working...
    Appriciate your advise tonsolve the issue..
  2. Gulfmaster
    Gulfmaster Notebook Guru
    Hi,
    Sorry, I'm travelling at the moment.
    the USB admin tool is bootable USB stick that you use to first create the samsung partitions. where did you get yours from? how did you create the recovery partitions?
    After updating to v6.1.0.1, the Admin Tool can be created by booting into the samsung recovery environment (using F4) and then pressing Ctrl+Alt+F10 to get into advanced options. The password to use is either "secos" or "secclx".
    Click on the option to create a USB Admin Tool.
    If you can't boot into recovery, use the images that have been posted in this thread.
    Dannemand likes this.
  3. Khaja
    Below is answers for u r questions..
    The usb admin tool that i have created is from this same post(mega) download.
    I have created the recovery partition by selecting the first 4 check boxes as mentioned in this post.
    I m in not able to boot into recovery environment once i installed the windowss. F4 link is not working.. System is not loading into recovery partition...hence i m not able to create usb admin tool.
  4. Gulfmaster
    Hi @Khaja ,
    Could you confirm that Fastboot and Secure boot are BOTH disabled?
  5. Khaja
    Yes, please refer my bios settins
    This is after installing windows. Previously i have set the order as described in this post.
  6. Gulfmaster
    Hi,
    1. I see that you have enabled password on boot. Could you disable it for the moment?
    2. You do not seem to have a "secure boot" option like mine (see screenshot). Please disable UEFI boot support for the time being.
    Francoise likes this.
  7. Khaja
    Hi,
    Many thanks for your quick reply..
    1.I haven't set the password on boot manually it is set as soon as i set the password for pc while installing windows.. I m not able to disable the password on boot as not enabaled for editing.
    2. Yes, i do not have option similar like you but i m not sure the reason..
    I m able to load neither windows nor recovery if i change the UEFI settins as windows 10 supports only UEFI
  8. CARDjy
    CARDjy Newbie
    Hi,
    I follow the whole process and can not restore the area of recuperation.
    when it arrives at the copy the files to the partition, nothing is copied and I've tried several times without success. Could someone upload the files on the partition to me ???
  9. Francoise
    Francoise Newbie
    Hi Gulmaster:
    I have a samsung laptop : np535u3c with a HD 500 GB and a SSD : 14 GB, I lost the recovery software preinstalled. Now, I can not install ant other windows on that laptop. What is the trick to install it ?, I can boot it with USB,, install fine, but when I take out the USB with the windows and restart the machine, noting happened. I wan to know I you have a recovery solution for that with Windows 7 Ultimate x 64 and if is in spanish, or where I can find it ?,, Is my wife laptop,, you know she want me in other place :) Thanks in advance
  10. John Ratsey
    Is the SSD for ExpressCache? If so, Windows will have installed the boot files on the SSD but the SSD isn't a bootable drive. The solutions for this are in the Sticky Thread. @Dannemand will know exactly where.
    John
