Guide; Power Options (power plans), show all hidden settings
Discussion in 'Windows OS and Software' started by t456, Dec 18, 2014.
  1. t456
    Pretty sure there's all kinds of little apps for this, but ... tinkering is way more fun :D .
    Anyway, you can use "powercfg /qh > t.txt" to list all hidden options and change the values from the CMD (since you now have the hidden GUIDs). But that's not just a little inconvenient, to be sure. Did some checking and it seems every hidden option has a specific dword value in the registry; "Attributes". Setting this to "0" will make the option show up in 'Control Panel' > 'Power Option' > 'Change plan settings' > 'Change advanced settings'.
    However, there's a lot of these (about 50). Secondly, also wanted this on a second system and the registry entries are dependent on a system's specific hardware configuration. Hence made this very quick & dirty spreadsheet;
    powercfg - show all settings
    It's editable and all, feel free to give it a try. Made for Windows 7, don't know about 8.x. Needs some modification if you download; Google f*'s up quotation marks when using regular paste (they vanish), the online version takes care of that. Mind you, very sloppy/inefficient formulas, so it's a bit slow. Just couldn't be bothered to spend more time on something I only need to use twice ...
    duttyend and Vistar Shook like this.
