[GUIDE] Installing and Overclocking the AMD Mobility 7970 in the M17x R3,an illustrated guide
Discussion in 'Alienware 17 and M17x' started by SlickDude80, Apr 24, 2012.
  1. SlickDude80
    SlickDude80 Notebook Prophet
    joey, are you still on the clevo drivers?
    Download these:
    AMD Catalyst 8.981.2 12.7 Beta – 7900 MOD – BenchmarK3D
    Within CCC software manager, do a complete uninstall of amd software
    Download driver sweeper and select "AMD Display", run, reboot
    now install the 12.7's...choose custom install and make sure everything is checked
    Install.
  2. The Revelator
    The Revelator Notebook Prophet
    No expert on the 7970M, but the video drivers you are using are telling your R3 that it has a 6800 card with a 128bit bus width.
    Try installing either the 12.5 Mod drivers ( AMD Catalyst 8.97 18 April – 7900 MOD – BenchmarK3D) or the 12.7 beta Mods ( AMD Catalyst 8.981.2.0 12.7 BETA June 26 – 7900 MOD – BenchmarK3D. These have worked for others.
    Also check PowerPlay in CCC to assure that it is enabled and set to Maximize Performance when plugged in. And plug it in. :)
  3. SlickDude80
    Joey, another thing...what vbios did Eurocom put on their 7970's?
    If reinstalling a new driver doesn't work, you may want to try a modded vbios from our friends at techinferno
    This is a dell vbios...I don't know what vbios eurocom put on these cards...i've heard that its is also the dell vbios, but not sure.
    Downloads | Tech|Inferno
  4. ashley-aitch
    ashley-aitch Notebook Enthusiast
    Did you fix the screen dim problem, i have this issue and have found no fix at all, apart from that closing and opening my lid brings the brightness back...
  5. ashley-aitch
    Do you think this will be fixed in a driver sooner or later?
  6. GeoCake
    GeoCake http://ted.ph
  7. SkylineLvr
    SkylineLvr Notebook Deity
    What should GPUZ be showing? That's exactly what my GPUZ screen tells me. I'm on the official 12.7 beta drivers currently.
  8. juliant
    juliant Notebook Deity
    Not any results so far. Some people do not complain about the brightness issue but I am sure everyone with an R3 has it.
    Does anybody have a link for creating a dos bootable USB drive to flash the vbios. I tried to create a membership on Tech | Inferno but did not allow me to create one and I cannot download anything from there. I followed Slick's link...
  9. juliant
  10. airacutie
    airacutie Notebook Consultant
    wow thx, will give it a try. rep+ :)
