[GUIDE] Installing and Overclocking the AMD Mobility 7970 in the M17x R3,an illustrated guide
Discussion in 'Alienware 17 and M17x' started by SlickDude80, Apr 24, 2012.
  1. BELL_IVY
    BELL_IVY Notebook Enthusiast
    yes i have it.
    i want to play BF3
  2. airacutie
    airacutie Notebook Consultant
    thx, 7970 and 680 are available on eBay now.
  3. SkylineLvr
    SkylineLvr Notebook Deity
    Can you play on stock clocks without any issue? Have you tried lowering your clocks?
    I have an issue with Crysis 2. I can only OC to 900/1350 on that game. Although I play it on stock clocks on Ultra settings. Any other game I can OC to 950/1500+ without any issues.
  4. ADegtyarev
    ADegtyarev Notebook Guru
    For the installation do we need to have the A08 unlocked bios (as mentioned in this guide) or would the most recent one from dell be better (A10)? Just wondering because upgradeyourlaptop instructions for installing a 7970m (from ebay upgrade kit for alienware page) said to update bios to latest version from manufacturer before installing the card. Also has anyone tried installation from upgradeyourlaptop steps, is it reliable?
  5. SlickDude80
    SlickDude80 Notebook Prophet
    THe problem with A10 is that it isn't unlocked and it downgrades your SATA's to SATA2 instead of SATA3
    Stick with the A08 unlocked...if it isn't unlocked, you can't disable the integrated graphics which will lead to problems for you.
    i don't know what the instructions are from eurocom, but it can't be much different than mine..except for the part at the beginning to disable integrated graphics in the R3
  6. juliant
    juliant Notebook Deity
    So, whatever it is SlickDude80, nobody has tried the 7970m with the A10 bios and had it working successfully?!
    I can put up with the switchable GPU (not really matters) but the brightness issue I cannot stand... I wish that we can have a fix shortly. I have tried everything possible including hdinfo, only what works is to keep the system on standby for few seconds and then will be ok.
  7. SlickDude80
    Geocake tried to enable integrated graphics when he got his hands on the clevo driver (with enduro enabled) and it was black screen city.
    Are you on 12.7? That has made my screen brighter...not perfect, but good enough as I usually turn it down anyways to relieve the stress on my gaming eyes
    I don't know anyone who has the card running on A10...but if you have a saturday where you're not doing anything lol...
  8. juliant
    My screen is bright enough (just like it should be), only after I put the system on standby for few seconds and back on (and this is not always).
    Switching between the integrated and dedicated is not an issue (you can always do that from bios if you really need that), only the bright issue if it is solved will be great.
    Maybe we should put this sticky on this thread page so that we may be lucky to get some help in fixing it...
    My screen now again has gone a bit darker (it is readable but not acceptable, maybe in the dark will do) after leaving it on standby for about an hour.
    And yes SlickDude80, I am on 12.7 beta (desktop) driver and the matter is not solved.
  9. SlickDude80
    i think the only way it will get solved is if you enable the igp...but it could be a headache if things go bad.
    For now, 12.7 has made my screen brighter compared to 12.5...not perfect, but better
  10. The Revelator
    The Revelator Notebook Prophet
    Actually, there is an unlocked A10 BIOS for the R3, thanks to svl7 and Bios-Mods. Not widely used, probably because of the SATA 3 downgrade issue, but it works fine, looks just like unlocked A08. I'm using it now to test. M17xR3_Unlocked_A10_Bios_Full.zip.
