[GUIDE] Installing and Overclocking the AMD Mobility 7970 in the M17x R3,an illustrated guide
Discussion in 'Alienware 17 and M17x' started by SlickDude80, Apr 24, 2012.
  1. The Revelator
    The Revelator Notebook Prophet
    Set IGP to Enabled. On the flashing matter, I was referring back to your earlier post where you said it wouldn't boot after set to PEG and Enabled, a common occurrence. Apparently I misinterpreted the post if in fact you were able to boot.
  2. ashley-aitch
    ashley-aitch Notebook Enthusiast
    Yea I tried this and still no fix, iv tried every combination and still no fix. When it boots using the IGD it works as it should... This has to be a driver issue.
  3. Redeka
    Redeka Notebook Consultant
    Clsoing my lid and opening it again causes my screen to return to max brightness as well, but only sometimes. Since I have discovered this, I am sometimes opening and closing my laptop 2 or 3 times before I begin my session :S
  4. BELL_IVY
    BELL_IVY Notebook Enthusiast
    why everytime i restart or turn off the alienware,my overclock back to default ??
    and why in the middle of the game my alienware always freeze ??
    i overclock at 950/1400
    (alienware m17x R4)
  5. ashley-aitch
    I feel your pain, so far this is the only fix I have found to work. I fear we must wait for a new driver of even a new vbios to flash.
  6. SkylineLvr
    SkylineLvr Notebook Deity
    Do you have MSI AB set to run on start up and have the OC run on start up?
    Your games are probably freezing because your OC is too high. Try lowering your clocks. Also, what game are you playing that you need to run 950/1400 to play?
  7. airacutie
    airacutie Notebook Consultant
    Guys, where are you buying this card? Still cant get it everywhere ...
  8. SkylineLvr
    Dell, ebay, eurocom.....
  9. airacutie
    Didnt tried Dell yet, but Eurocomm still doesnt have it on eBay ...
  10. Redeka
    You have to send them a message through ebay. Or you can message Dan Ross directly at dross (at) eurocom (dot) com
