[Guide] Improving Battery Life on Windows [+Enabling Deeper C States]
Discussion in 'Windows OS and Software' started by Che0063, Apr 14, 2018.
What was your increase in battery life after following this guide?
  1. None (decreased)
    33.3%
  2. 20%
    6.7%
  3. 40%
    40.0%
  4. 50% +
    20.0%
  1. Vasudev
    Have you tried new TS 8.76?
  2. Mobius 1
    Mobius 1 nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ⎬⎛⎝⎠⎞⎨
    whoops, will update
  3. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    OK, I gave it a try.
    Now my machine is reliably achieving over 4hrs (sometimes by a few minutes, LOL) of battery life according to battery report, while it sometimes dropped lower than that before. Not much of an improvement, honestly - but then again my laptop does run something all the time, always on VPN eats about an hour of battery life, and so on.
    Most services seem useful. )'=
    Edge is a crappy browser; wanted to use it for Youtube only but it's terrible, stops showing videos after sleep - and unsuitable as main browser due to lack of privacy features. Movies&TV can't do volume boost, unusable for watching most movies.
    Done.
    Done.
    Done, though mildly.
    Done.
    My CPU was entering deeper CPU states even without the tricks.
    Skipped.
    Skipped.
    Done.
    Mine is fine, skipped.
    Don't usually attach anything to my laptop.
    Skipped - will replace with higher capacity someday, anyway.
    Can't live without mine, skipped.
    Vasudev likes this.
  4. Mr.K-1994
    Mr.K-1994 Notebook Consultant
    Common sense will work pretty well against viruses.
    Che0063 likes this.
  5. Starlight5
    Common sense doesn't work against misclicks.
    Vasudev and Aroc like this.
  6. xLima
    xLima Notebook Consultant
    Thanks for this post, easy to follow, thoroughly explained; however, I don't achieve the C0% <1% on all core/threads, I always have my first 4 core/threads fluctuating to 14, 10, 6, etc., as such I am unable to sit under <0.5W consistently. I tried running with the park policy @ 16% and 0%, nothing seemed to work. But overall pretty happy, my max wattage on idle was 1.4W if I am not mistaken.
    MSI GS65 (i7-8750H; GTX 1070 Max-Q) 512GB Samsung PM981 NVMe OEM SSD
    I updated the Samsung NVMe Drivers.
  7. Che0063
    Che0063 Notebook Consultant
    The 8750H is pretty powerful... It should idle very easily. I got my friends' 7700HQ down to 0.3W on idle CONSISTENTLY; The 8750H is basically the 8700HQ so I'm not sure what's happening there.
    Vasudev likes this.
  8. Vasudev
    Samsung NVMe drivers increase power usage, so if you want better power try default MSFT driver.
    Maleko48 and Che0063 like this.
  9. Maleko48
    Maleko48 Notebook Evangelist
    Interesting, I use the Samsung drivers and it seems like I still get good results. I don't want to risk messing with swapping around for testing though.
  10. xLima
    Does Fast Boot have any effect on battery life? Would it be better to disable it?
    I am finding conflicting information on line.
    Sent from my BLA-L09 using Tapatalk
Similar Threads - [Guide] Improving Battery
  1. hackness
    96
    20,377
