[GUIDE] How to change your Dell MediaDirect button's functionality
Discussion in 'Dell' started by BatBoy, Aug 15, 2008.
  1. hankaaron57
    hankaaron57 Go BIG or go HOME
    You are a god batboy! Glad to hear you're still catering to the XPS community too!
    Quick question: I downloaded your original turnofflcd.exe way back when. Is this batch file something that can be reversed? I just want to try it out before I decide to replace the current executable file. I don't know that I want to bother with a password when I turn off the screen just yet, just want to try it out at this point as I feel getting in the motion of locking the system when I leave needs some trial before a final decision.
  2. BatBoy
    BatBoy Notebook Nobel Laureate
    You dont need to download the TurnOffLCD.exe again. the batch file is just a couple of lines of instruction which tell the OS to run TurnOffLCD.exe and then 2 seconds launch and close the lockworkstation shortcut.
    Dont worry about the ping command - its an easy way to basically include a pause in the batch commmand - the OS will ping your local machine - thats it.
    You'll need to create the batch file and shortcut. If you don't like the result, just delete the batch file you created and change the registry entry to point to turnofflcd.exe instead of the batch file :)
  3. arjunned
    arjunned Notebook Deity
    This is brilliant!! Thanks bro. +1
    Cheers! :D
  4. BatBoy
    No worries. Glad to help out the community. :) Have you implemented the remapping under Windows 7 or XP x64? I'll update the notes to reflect compatibilty with those two based on your reply. Thanks!
  5. arjunned
    Yup. Works perfectly on both W7 x64 & XP x64. :)
    Thanks again.
  6. BatBoy
    Excellent - thanks for the confirmation!
  7. elixir1018
    elixir1018 Notebook Enthusiast
    you are the stuff amazing is made of, thanks for helping me out so fast!
  8. ps89
    ps89 Notebook Consultant
    Hello there. I'm interested in this. Do I need to have Quickset installed before adding the registry keys from the attachment? I'm using Windows 7 x86. Thanks. :)
  9. BatBoy
    Install Quickset - the the registry keys should be created automatically.
  10. discovery
    discovery Notebook Guru
    sorry for the dumb question. I have remaped the media direct key to firefox.
    What happens if I delete the Media Direct partition and try to push the Media Direct button?
