[GUIDE] How to change your Dell MediaDirect button's functionality
Discussion in 'Dell' started by BatBoy, Aug 15, 2008.
  1. BatBoy
    BatBoy Notebook Nobel Laureate
    NOTE: This was written for Vista back in 2008. I no longer have a Dell lappie with a MediaDirect button so I cannot adjust this for W7 nor test. See post here for W7 instructions.
    - How to change your Dell MediaDirect button's functionality -
    There have been many posts asking how to change the function of the Dell MediaDirect button (the little house). I thought it might be easier for people to reference if the basics were all located under one thread. What follows is the process I use.
    Couple of important bits of info before we begin:
    1. This process DOES NOT require you have MediaDirect. Quickset is required as Quickset creates the Registry Keys which we need and handles the routing.
    2. Tested and verfied compatible with MediaDirect 3.5, MediaDirect 4.0, Quickset 8.2.20+. Works with Vista 32/64, XP 32/64 and Windows 7 x64. (Thanks to arjunnedfor confirming XP and Win 7 x64)
    BE AWARE, WE WILL BE EDITING THE REGISTRY. IF YOU MAKE A MISTAKE OR CHANGE SOMETHING BY ACCIDENT, YOU CAN HOSE YOUR SYSTEM. BACK UP YOUR REGISTRY IF YOU FEEL THE NEED. IF YOU DO NOT FEEL COMFORTABLE, STOP NOW.
    Without further delay, let's get started.
    1. We will need to modify a couple of registry keys. Open REGEDIT via the RUN command (type REGEDIT). This will launch the REGISTRY EDITOR. (Again, if these keys are missing, just create them).
    Find the following keys...
    HKey_Local_Machine\SYSTEM\CurrentControlSet\Control\MobilePC\HotStartButtons\0
    HKey_Local_Machine\SYSTEM\ControlSet001\Control\MobilePC\HotStartButtons\0
    HKey_Local_Machine\SYSTEM\ControlSet002\Control\MobilePC\HotStartButtons\0
    HKey_Local_Machine\SYSTEM\ControlSet003\Control\MobilePC\HotStartButtons\0
    *Note: You may note have ControlSet003 - if not, don't worry. Just proceed.
    For each of these keys, there is an Application Path entry. This is the entry you will need to modify.
    When looking at it, it will look like this:
    "C:\Program Files\Dell\MediaDirect\MDirect.exe"
    2. In order to remap it to launch another application, just edit the path to whatever application you want. So, for example:
    To map it to launch Windows Media Center, you would change the path to:
    "C:\Windows\ehome\ehshell.exe"
    You now have the process to change the mapping to any application you have. Just point the application path to the application you want the button to launch.
    *NOTE: After modifying the registry, you will need to reboot for your changes to take effect.
    POWER OFF LCD
    Fr0stbite posted a request to change the button functionality to power off the LCD. This is also possible. In order to do this, use the following process:
    1. Download TurnOffLCDv101. It's a small 85kb application that is Freeware*
    2. Extract the file to your desktop or another location.
    3. Assuming you saved TurnOffLCDv101.exe to the Program Files folder, when editing the registry, you would change the ApplicationPath key to:
    "C:\Program Files\Turn Off LCD.exe"
    Thats it! Now after rebooting, depressing the MediaDirect button will turn off the LCD. Moving the mouse or pressing a a keyboard key will power on the LCD.
    *Thanks to Taimur Asad for writing this little Application.
    LOCK WORKSTATION, RESTART, SHUTDOWN:
    You can also use this same process to perform these functions.
    So, for LOCK WORKSTATION you would:
    1. Right-click an empty space on your desktop, point at New, and then select Shortcut.
    2. Type rundll32.exe user32.dll,LockWorkStation in the location field and then press Next.
    3. Type the name of the shortcut in the name box ("LockWorkstation").
    4. Click Finish to create the shortcut. To keep the desktop clean and free of clutter, move the newly created shortcut to the root level of your C: drive.
    5. Now, in the Application path of the registry edit process, change it to point to your LockWorkstation shortcut.
    "C:\LockWorkstation"
    6. Reboot.
    Pressing the MediaDirect button will now lock your lappie. Granted its probably just as fast to use keyboard shortcuts, but some people may find it useful.
    Try this for a SHUTDOWN shortcut which will force all open application to close the system to shutdown:
    Shutdown.exe -s -t 00
    or to give the system 30 seconds, use this:
    Shutdown.exe -s
    For SLEEP, try:
    Rundll32.exe Powrprof.dll,SetSuspendState Sleep
    for HIBERNATE, try:
    Rundll32.exe Powrprof.dll,SetSuspendState Hibernate
    Again, once you have identified the shortcut/application/file you want to link the button to, just go into the registry as before and change the Application Path. You can link to any shortcut you create... Why not set it to launch a favorite website like NotebookReview's Dell Forum? Kind of cool huh? :)
    Well, there you have it. Enjoy! Feel free to PM me if you have any questions.
  2. Chucklz_smiley
    Chucklz_smiley Notebook Consultant
    Really Useful guide thanks for posting BatBoy:D
  3. tom_baker
    tom_baker Notebook Guru
    Really useful! No doubt I'll be using this when I set up Dells into the future!
    --Tom
  4. X2P
    X2P COOLING | NBR Super Mod
    Will this work for "any" dell notebook?
  5. atbnet
    atbnet Notebook Prophet
    Great guide, I will use this when my M1730 gets here. Do you know how to set it to sleep or hibernate? I haven't been able to find a clear cut answer for Vista.
  6. Forte
    Forte NBR's Supreme Angel
    If you press the power button once it goes to sleep.
  7. atbnet
    I suppose I could do that, but I was aiming for a shutdown and sleep button. I suppose I'll just opt for restart or map it to something else.
  8. Arsenaly
    Arsenaly Notebook Guru
    Great guide. umm Can you map it to boot xp?
  9. thegman
    thegman Newbie
    wow...great guide, thanks
  10. BatBoy
    Yes. It will work with any Dell that has a MediaDirect button (house) on the keyboard and has Quickset installed.
