Guide: How to block Alienware Command Center from automatically updating
Discussion in 'Alienware' started by Spartan@HIDevolution, Jun 5, 2020.
  1. Spartan@HIDevolution
    If for any reason you don't want Alienware Command Center to update to a newer version, then here's how you can block it.
    1) Press the Windows Key + R to launch the run dialogue box
    2) Type regedit then hit Enter
    3) Navigate to the following key:
    Code:
    HKEY_LOCAL_MACHINE\SOFTWARE\Alienware\Alienware Command Center
    4) Double click on the string value "InstallVersion" and edit the value to 5.2.106.0 or whatever the latest version is at the current time.
    alberty and Virale like this.
  2. Virale
    Virale Notebook Evangelist
    Surely changing the string to a really high number should achieve the same and prevent updates. Maybe worth a shot? Set it to something like 5.9.99.0? Or even 10.9.99.0? If all previous versions follow the same versioning number convention, this should work. I imagine it is a dumb checking logic ala “is my installed version number < the server version number? If yes: update. If no: no action”.
    Try it!
  3. custom90gt
    Can't you block the application in the windows firewall? It's what I've done for other applications that I couldn't stand the latest "updates" on.
  4. Papusan
    Papusan TURDBOOKs Sucks! Dont waste your $$$ on FILTHY
    I mean this isn’t enough. Have seen some mentioned it will start updating later. Maybe an algorithm in the software change the settings.
    Spartan@HIDevolution and DreDre like this.
  5. custom90gt
    I'm confused on how that can be? If it can't get in or out of the internet, how does it update? Does it have a separate update program? Get updates from windows updates?
    Super annoying to be sure, but I'm the kind of guy that blocks windows updates on everything and manually installs updates that I think are "worthwhile."
    DreDre and Papusan like this.
  6. Papusan
    I don’t know what to think. But here’s the post http://forum.notebookreview.com/thr...-owners-lounge.826831/page-2187#post-11019446
    Yeah, everything is locked on my machines.
  7. Spartan@HIDevolution
    FW limitation mentioned here.
    This is the same reason why if you block the latest CCleaner from the Firewall rules only, then try to launch it, it will take a long time before it starts as it is still trying to establish a connection with Piriform and Avast to spy on you so the way around that is to add the below entries into your HOSTS file.
    Code:
    0.0.0.0 ncc.avast.com
    0.0.0.0 ncc.avast.com.edgesuite.net
    0.0.0.0 ipm-provider.ff.avast.com
    0.0.0.0 shepherd.ff.avast.com
    0.0.0.0 ip-info.ff.avast.com
    0.0.0.0 analytics.ff.avast.com
    DreDre, Papusan and custom90gt like this.
  8. custom90gt
    Can you not add dell update repositories to the hosts file then too?
  9. Spartan@HIDevolution
    1) I don't know how
    2) I don't want adding those entries to impact any other functionalities of the system as others may still want to use SupportAssist, Dell Update, Dell Digital Delivery, Alienware Connect, etc.
    This is a safer method
  10. Papusan
    Those have a ticking bomb. Both for security and trashed hardware performance.
