guide, - get better sound on your Dell laptop
Discussion in 'Dell' started by KSMB, Jun 4, 2007.
  1. KSMB
    KSMB Notebook Deity
    this guide is for Dell 9400/m1710/M90 (but i think its works for all Dell laptops with Sigmatel sound card). if you do this steps, you get a much better sound. (i use XP)
    1. bring the Sigmatel driver from Dell.com
    http://support.dell.com/support/dow...-1&impid=-1&formatcnt=1&libid=3&fileid=162467
    2. completley remove your "old" Sigmatel driver from your computer, (restart your computer, just incase).
    3. zip up the "new" driver, BUT stop just before the computer want to install it completley. (here you stop. just terminate the installation)
    4. bring this file to you computer (and zip it up).
    http://www.notebookforums.com/attachment.php?attachmentid=11288&d=1156277456
    5. go to C:\DELL\drivers\R122161\WDM.........then paste the file (92XXM2-3).
    6. double-click on the EXE-file (C:\DELL\drivers\R122161), and complete the installationen of the
    Sigmatel driver..............restart your computer...........now you done.
    then it looks like this (MUCH better bass sound and other sounds as well).
  2. israelcanouan
    israelcanouan Newbie
    nice, but i can not use my headphones why???:mad:
    My headphone jack dosen't work i got only sound for the speakers. ...
  3. mtor
    mtor Notebook Deity
    Have you checked your settings to make sure it is enabled
  4. RotJ
    RotJ Newbie
    Do the default settings give better sound or do you have to tweak the advanced settings and equalizer?
  5. israelcanouan
    Yes i did, any other suggest???
    still not working, but my jack mic works perfect the problem it's with the headphone.
  6. KSMB
    KSMB Notebook Deity
    for the first , xp or vista ?.....(you have a Dell 9400/e1705/Xps m1710/M90 ! )
    do the steps right and you will get a MUCH better sound. it really works (knows a lot of people who use this file, works for everyone of them).
  7. israelcanouan
    I use XP Home my system 9400.
    i will try uninstall the drivers and install again.
    should work.??
    but in the new control panel when i go to the jack setup i select jack microphone and change to pink, but the headphone do nothing.
  8. israelcanouan
    well i uninstall and install and no work...:mad:
  9. Psychokitty
    Psychokitty Notebook Guru
    This doesn't work with all Sigmatel cards.
  10. israelcanouan
    Thank's Psychokitty i back to the original driver's, my headphone works perfect.
    it's sad no works with my card.:mad:
  11. Psychokitty
    I have the Sigmatel 975X driver in my I9200.
    BUT...
    If you have XP, you can go into the regestry and increase the options on your Windows volume control panel.
    Start\Run and type " regedit "
    Browse to:
    HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings
    (As always before editing the registry, right-click the folder, and click "Export". Select a place to export a copy of that registry folder. This is backing up that part of the registry in case you do not like the results of changing it, or you mess it up. All you have to do is click on the ".reg" file, and it will ask you if you want to add it to your registry.)
    DWORD values with "01" mean "yes", and "00" means "no".
    You can edit a DWORD value by right-clicking, and selecting "Edit". In the pop-up menu, highlight the last two numbers (either "00", or "01") and replace them with what you want.
    You will see that many controls are disabled. Some are disabled simply because the card does not support them. But others are not. Do a few at a time. Don't do any you do not understand, and if any changes don't produce a result, change them back.
    When you close the registry, open the properties of the volume control. Here you will see check boxes that need to be checked. Close out and double click the volume icon in the task bar. The fun begins!
    Here is what my changes look like...
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings]
    "3DDepthEnable"=hex:01
    "AuxMute"=hex:01
    "AuxVolumeFixedLevel"=hex:01,01
    "BiosType1"=hex:01
    "CDMute"=hex:01
    "CDVolume"=hex:00,00,eb,ff
    "CenterMute"=hex:01
    "CodecPowerUpDelayInMCS"=dword:000003e8
    "CPL_MaySwitchExtAmpPowerState"=hex:00
    "CPL_SaveExtraPower"=hex:00
    "CPL_SecondsAfter"=dword:0000000f
    "CPL_SpdifTransmitterEnabledByUser"=hex:01
    "CPL_UserControlsOnlyOnOff"=hex:01
    "DigitalMuteControlsAnalog"=hex:01
    "Disable3DControl"=hex:00
    "DisableAux"=hex:00
    "DisableCDIn"=hex:00
    "DisableHeadphone"=hex:00
    "DisableLineIn"=hex:00
    "DisableLnlvl"=hex:00
    "DisableMicFromPlayback"=hex:00
    "DisableMICSelect"=hex:00
    "DisableMonoOut"=hex:01
    "DisableMonoVirtual"=hex:01
    "DisablePCBeep"=hex:01
    "DisablePeakmeters"=hex:00
    "DisablePhone"=hex:00
    "DisableSubwooferAtMono"=hex:01
    "DisableVideo"=hex:00
    "DisableWaveIn2"=hex:00
    "EmulateAllMasters"=hex:01
    "EnableExtAmpControl"=hex:01
    "EnableMuteReg02InMasterAdvanced"=hex:01
    "EnableNonPCMOnWin2K"=hex:01
    "EnableSubwooferAtMono"=hex:01
    "ExtAmpPowerDownTimeInMCS"=dword:00001388
    "ExtAmpPowerUpTimeInMCS"=dword:00001388
    "GPIOActions"=hex:00,00,00,00,00,01,02,01
    "GPIOControl"=hex:01
    "GPIOSPDIFControl"=hex:01
    "HeadphoneMute"=hex:01
    "LFEMute"=hex:01
    "LineInMute"=hex:01
    "MasterControlsAux"=hex:01
    "MasterControlsMono"=hex:00
    "MasterMute"=hex:00
    "MasterVolume"=hex:00,80,ef,ff
    "MasterVolumeFixedLevel"=hex:00,00
    "MICAtRecMuxVolume"=hex:00,30,10,00
    "MonoMixerAtMonoOutVolume"=hex:00,00,00,00
    "MuteInactiveDAC"=hex:00
    "MuteReg02InMasterAdvancedDefault"=hex:00
    "PCBeepMute"=hex:01
    "PCMVolumeFixedLevel"=hex:08,08
    "PCMVolumeFixedLevelEQ"=hex:06,06
    "PhoneMute"=hex:01
    "SubwooferAtMonoVolume"=hex:00,00,00,00
    "SurroundMute"=hex:01
    "TrueLevelMute"=hex:01
    "VideoMute"=hex:01
    "WaveInMux"=hex:00,00,00,00
    "WaveIn2Mux"=hex:01,00,00,00
    "MultiChannelEnable"=hex:01
    Now if you trust me, (and I make NO guarantees about ANYTHING, nor do I take ANY responsibility for anything but good results! :p) then you can copy everything in between the lines (not the lines) on to your notepad, you can save it as "what ever you want to call it".reg, and then click on it, and it can be loaded right into your registry.
    But like I said, always back up your registry before making such changes.
  12. Psychokitty
  13. KSMB
    KSMB Notebook Deity
    It Works To All Sigmatel Cards If You Have Xp And 9400 AND HAVE THIS R122161.EXE SIGMATEL DRIVER WHISH NEARRLY ALL 9400 HAVE!
    when you plug in your headphones, just choose the second alternativ, and of you go.
    (its MANY people on notebook forum who use this awesome sound change).
  14. Dell_6400_fan
    Dell_6400_fan Notebook Consultant
    Unfortunately this does NOT work in Vista. I just tried it a little while ago. It doesn't open up the feature set as this driver does in XP. I hope they release an updated INF file to open up features for the Sigmatel HD Audio chip found in the Inspiron's running Vista.
    Great find anyway!
    On a side note, I've been using DFX Audio Enhancer v8 and it does wonders for my speakers. It's basically a software EQ with tonnes of presets (or you can manually set).
  15. Psychokitty
    R U YELLING AT ME?!
    You first stated " this guide is for Dell 17" (but i think its works for all Dell laptops with Sigmatel sound card). "
    I was just confirming that it only works on the 92xx series Sigmatel cards, that's all.
  16. KSMB
    KSMB Notebook Deity
    sorry, not meant like that. (but i also wrote i "think" its works for all sigmatel...... NOT i know its works for all sigmatel.....). but i know its works if you have a 9400/m1710/M90 and use XP and of course have the R122161.EXE SIGMATEL DRIVER.
    hope the others guys work it out, the sound (specially the bass) gets a lot better, when you use this file.
  17. KSMB
    KSMB Notebook Deity
    yes, you need to change (tweak) the equalizer to get better sound. (default settings sounds like it normally does).
    i remember first time i heard the different, wwooaahh, it was really awesome. so much better sound now.
  18. sydney_australia
    sydney_australia Notebook Guru
    wow - this is amazing.
    i have the 9400 and it only has the default sound card right
    but now im gettinmg the m1710 and it has the audigy sound blaster softeware
    what u showed above - isnt that already on the m1710
    or do i have tpo update dreivers / firware
  19. PhoenixFx
    PhoenixFx Notebook Virtuoso
    Tried both hacks but doesn’t work with M1210.
    1. I think M1210 uses 92XXM8-2.INI instead of 92XXM2-3.INI, because the device ID of the currently installed driver can only be found in 92XXM8-2.INI file. If I get some free time I will try to modify 92XXM8-2.INI with the changes of 92XXM2-3.INI, who knows, it might work.
    2. For M1210 those registry settings are stored under {4D36E96C-E325-11CE-BFC1-08002BE10318}\0005\Settings not under 0000. I tried merging them to 0005 but still didn’t work.
    Since the M1210 has a 5.1 output, maybe it is different. :(
  20. KSMB
    KSMB Notebook Deity
    sydney_australia, the m1710 has the same sound card and settings like 9400/e1705, (you have to order beside to get a other sound card), so yes, this file works for m1710 as well.
    dont forgett, i use XP (all who get this modd working, use XP)....vista sucks...he he
Similar Threads: guide better
Forum Title Date
Dell Has anyone done a Win7 "Install and bloatware removal guide" Feb 18, 2010
Dell Dell System Recovery Guide Jan 21, 2010
Dell Dell Parts Guide Apr 2, 2009
Dell [GUIDE] How to change your Dell MediaDirect button's functionality Aug 15, 2008
Dell Guide: Love your SEC Screen Apr 16, 2008
