[GUIDE] - Blind-Flashing AMD 7970M modded vBIOS for Clevo P1xxHM Laptops
Discussion in 'Sager and Clevo' started by jaybee83, Sep 17, 2012.
  1. psarrism
    psarrism Notebook Consultant
    Which drivers do you use?
  2. SetOnFire
    SetOnFire Notebook Enthusiast
    Installed the last Catalyst 12.11 Beta 6
  3. Meaker@Sager
    It's to do with the ram clocks I believe, changing between the idle and load states, you could try modifying the idle ram clocks, I think someone manage to unlock overdrive with -XCL at the end of the shortcut to MSI afterburner? I think you could then create a clock profile for 2d too....
  4. Marecki_clf
    Marecki_clf Homo laptopicus
    UnofficialOverclockingMode = 2
    in MSIAfterburner.cfg file fixes the screen flickering problem. The drawback is that it disables PowerPlay.
  5. jaybee83
    jaybee83 Biotech-Doc
    ^^^ yep thats correct. setting the OC mode to 2 will take care of the flickering. it will reset after each reboot tho, so ull have to do it manually every time u want to OC ur card.
    awesome clocks btw! congratz ;)
    Sent from my Galaxy Nexus using Tapatalk 2
  6. SetOnFire
    Thanks to you for the great guide and everybody answered to me.
    The OC mode 2 is a good workaround so far, but i hope to find something that makes it work without giving up the powerplay.
    Maybe patching furtherly the bios working on the 2d voltage and frequencies?
  7. Marecki_clf
    It doesn't reset after reboot on my machine.
  8. jaybee83
    ah ok, thx for the info
  9. Marecki_clf
  10. SetOnFire
