[GUIDE] - Blind-Flashing AMD 7970M modded vBIOS for Clevo P1xxHM Laptops
Discussion in 'Sager and Clevo' started by jaybee83, Sep 17, 2012.
  1. apollonx
    apollonx Notebook Enthusiast
  2. apollonx
    How vbios is changing? Who wrote vbios to hd7970? Help
  3. jaybee83
    jaybee83 Biotech-Doc
    well, thats the thing, no one here did the modding, we just used an already modded vBIOS off a card that was purchased at a retailer. not sure if vbios-cracks like svl7 or prema could help out there...
  4. apollonx
    @jaybee83, Thank you very much for your concern.
  5. johnnyman27
    johnnyman27 Notebook Lover
    guys today i installed my 7970m and flash the modded bios in this page but the stock voltage is 0.98..how is that possible to be so low?thx!!
  6. Apu71
    Apu71 Notebook Geek
    Hey guys, I have a p150em and I flashed a bad VBIOS on my 680m but I have a friend with a p150hm that I could use to flash my card possibly. The only hang up I can think of is that he has a 6990m and I have a 680M. With that cause any problems? And also is there an auto exec file that I can use or should I just use the manual commands?
    Sent from my HTC PH39100 using Tapatalk 2
  7. jaybee83
    with the p150HM it doesnt matter if u got an AMD or Nvidia gpu installed, its all the same revision/mobo :)
    u could easily come up with an autoexec.bat urself. just create a .txt file with all the appropriate commands in it and convert it to a .bat file with the name "autoexec"
    done ;)
  8. SetOnFire
    SetOnFire Notebook Enthusiast
    I got a P150HM with an old 6970. Soon I will upgrade with 7970, and i guess it will worth.
    Thanks for your very useful guide, i'm curious to compare it with the great GTX680m. I'll let you know.
  9. Meaker@Sager
    680M is great for modders who want to take things to the extreme, the 7970M is a great bang for the buck card, especially in dedicated card only setups.
  10. SetOnFire
    Well. I got the card and i installed following the guide.
    Everything went perfect with the blind flashing, modding the bios at 1.075v and overclocking till 1050/1450 and the result are amazing.
    The only bothering thing I experience is that when I overclock from the stock 850/1200 to even 900/1200, the screen starts flickering while i move the mouse around the screen. But if I run a 3D application, it fixes and i can play steady. Is there any problem maybe from the sync from 2D to 3D applications? Anyone had the same problem and knows how to fix it?.
