[GUIDE] - Blind-Flashing AMD 7970M modded vBIOS for Clevo P1xxHM Laptops
Discussion in 'Sager and Clevo' started by jaybee83, Sep 17, 2012.
  1. Meaker@Sager
    Yep, you can't on a switchable setup unfortunately.
    Also yes, always good to explore each core voltage to find which gives the best performance/temp for you.
  2. By_cleiton
    By_cleiton Notebook Consultant
    Hi guys! I came here to ask for some help!
    I have a 7970m in my g73jh but I want to undervolt it
    But I only be able to find vbios with high voltages
    Could someone that have contact with svl7 to md this vbios?
    Thanks a lot and I found a way to do it in CCC profile but I think
    It isn't working because gpuz shows the same stock 1.0 v
    http://forum.notebookreview.com/gam...0m-benchmark-results-only-68.html#post9059190
    Thanks again
    Bye
  3. jaybee83
    jaybee83 Biotech-Doc
    hmm...go ahead and try different values for the undervoltage, cuz i think that the gpu core has predefined voltage steps that dont allow and intermittent values. for example it would only support 0.95v but not 0.99 or anything else between 1.0 and 0.95v. so go ahead and play around with that first, see if it helps any :)
    also make sure to give some feedback on ur results here, would surely help other users!
    cheers
  4. By_cleiton
    Hi guys I came back again
    I tried to undervolt my card without any lucy but i was able to increase the voltage from 1 to 1.05 and it worked perfect! I did a OC to 950/1400 with no problems but the undervolt that i want to do it isnt possible yet! so sad....
    Maybe a vbios
    Bye
    Edit
    Hit 1000/1400 1.05v =D
    http://www.3dmark.com/3dm11/6059066
  5. F1r3
    F1r3 Notebook Consultant
    Nice score for a Intel 720QM xD
    Is there a chance to upgrade your CPU to a 920XM or something like that - but now your CPU is holding back your 7970m in performance.
  6. By_cleiton
    Yes I know!
    I did a little bit oc to my 720 with setfsb to 1.83 and hit p6111 on 3dmark11
    Imy temps were 75c but in real game scene I saw temps like 84
    It is ok because my room was very hot!! I live in brazil so the temps here is so high
  7. Meaker@Sager
    Yeah the temperature issues are not so much here in scotland!
    The 920Xm overclock may introduce power/heat issues and for gaming he should be good even with the 720qm.
  8. jaybee83
    talking about scotland! watching braveheart right now, havent seen this in ages! :D
  9. Meaker@Sager
    Yes a perfectly historically accurate rendition of the region :p
  10. jaybee83
    of course! i take it for granted that ure still all running around in dirty skirts and faking that wonderful scot accent, all the while bickering about whos to be king of scotland and how to get rid of those damn english! :D
    Sent from my Galaxy Nexus using Tapatalk 2
