Gtx 980m mxm by clevo not detected
Discussion in 'Hardware Components and Aftermarket Upgrades' started by code9523, Apr 15, 2019.
  1. code9523
    code9523 Notebook Enthusiast
    Hello!
    Who had sereously worked on gtx980m mxm 8gb clevo i need your help.
    Got the card with unknow issue. All i can tell that it has no sereous shorts or something but vbios chip gets only 1.0v and it should get an 3.3v to start correctly. I tried the chip on the programmer and read and write tests are sucessfull i also tried to replace it with another chip but no luck. Only 1.0v is going to it. I checked all voltages on card and it has 3.3v 5v and 19v present. The laptop will post only with igpu. I also checked wit same working card and laptop detects it with no issue. So there must be an ic or voltage regulator which powers on an bios chip but i dont know which one is it. As there are 5 controllers on the card and swapping each is pretty hard.
    Thank You for any help or advise!
