GTX 1070 on HP EliteBook 8770W DC - it works!
Discussion in 'Hardware Components and Aftermarket Upgrades' started by mirage_bg, Oct 31, 2019.
  1. mirage_bg
    mirage_bg Notebook Deity
    Just as the title says - it works!:)
    I tried one MXM 3.0b GTX 1070 , which I found new and relatively cheap on feebay and it worked like a charm. I did put some LM on the GPU - 73-74C max after half an hour of FarCry 5.
    Some pics and benches:
    [​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG]
    Not bad for almost 7y.o. grandpa....;)
    i-Diot, Ashtrix, Mr. Fox and 4 others like this.
  2. yrekabakery
    yrekabakery Notebook Virtuoso
    Nice! Looks like a 115W 1070N from the Heaven score (Fire Strike is too low-res to read), which might be the first time I’ve seen a 1070 in standard MXM-B that is not Max-Q.
    mirage_bg likes this.
  3. Reciever
    Reciever D! For Dragon!
    Nice work!
  4. mirage_bg
    Yes, 122W max on load.
    Ashtrix and yrekabakery like this.
  5. yrekabakery
    Nice. Have you tried overclocking yet?
  6. mirage_bg
    It already runs at 85C, no much temp room for OC I think...
  7. yrekabakery
    The card is TDP locked, so OC won’t increase temps, it’ll simply run high clocks at lower voltages. Pascal/Turing OC is quite different from OC on previous architectures. It’s more similar to undervolting.
  8. mirage_bg
    Here it is +200Mhz core OC:
    [​IMG][​IMG][​IMG][​IMG]
    yrekabakery likes this.
  9. yrekabakery
    Looks good. Your Heaven score is what I expected, but the FS Graphics Score is a bit low (the OCed score should be what it gets at default), I wonder why. Also I would up the memory OC to +500 in Afterburner as well, as the the GTX 1070 is quite memory bandwidth starved due to using GDDR5 instead of GDDR5X, and those Samsung 8Gbps GDDR5 chips are good for at least 9Gbps.
  10. mirage_bg
    Is it possible the CPU to hold the GPU back? (Thats why it gets lower FS graphics?)
