gt73vr 7rf titan pro ram help
Discussion in 'MSI' started by raserdk, Aug 12, 2018.
  1. raserdk
    raserdk Notebook Geek
    ok i have a pair of MSI24D4S7S8MB-8 so 16 gb in total
    then i bought a pair of the same with the same model number, i installed them, and started the laptop but black screen
    when i remove the ram i can start the system again,
    is the ram defective? or do i have to do something else
  2. Falkentyne
    Falkentyne Notebook Prophet
    Did you wait 3 minutes before giving up?
    Also try holding down the power button for 50 seconds, then release it, then wait *three* minutes.
    Should start boot looping after 3 minutes (keep waiting) until it finishes.
  3. raserdk
    ok when i press and hold the power butten it powers on then off and stays off, then i have to plug in the power supply before i can power on, after that i just stays on with black screen, it did that for about 10 minutes, when i remove the modules, i do the power butten thing it does what you say boot looping 3 times and then starts up, but not with the two other dimms occupied
  4. Falkentyne
    @raserdk
    That means the two RAM dimms you inserted are defective.
    When I bought two Kingston Valueram dimms off amazon and put them in to add to my existing 2x8GB "MSI" dimms (which are simply Kingston Valueram with a MSI SPD), I had no problems.
    RMA the two sticks you bought. How did you even buy them to begin with? They aren't for sale. They must have been discarded used parts (pretty obvious why they don't work).
    This is the stuff you want.
    https://www.amazon.com/gp/product/B01LW6HBSM/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
    raserdk likes this.
  5. raserdk
    bought them used, off ebay, creating a dispute now :) thanks for your help
    Falkentyne likes this.
