GT627 memory clip fix
Discussion in 'MSI' started by MrAwesome, Dec 4, 2011.
  1. catacylsm
    catacylsm Notebook Prophet
    True that dave, one thing the MSI books suffered from was massive amounts of dust building along the inner HS Vents, removing the fan off showed me an apserlute truck full of dust blocking the air from flowing adequately!
    Fan off and a blast of compressed air and your temps should dive!
  2. Meaker@Sager
    Fit module in and secure down with electrical tape, job's a gooden.
  3. MrAwesome
    MrAwesome Newbie
    So i went with 2x2gb option, and taped the loose stick in with electrical tape, hopefully it'll hold, if not, i think it might be okay, simply because the case will block it from popping out too far, not safe, but working!
    I tried to go about cleaning my fan, but there's a damned metal plate over the top of it that has no obvious ways to remove, i'm not sure how i'm going to get in there without breaking it off -.- i don't think it even does anything, lol. i'll try get a pic of that in a bit.
  4. Kirrr
    Kirrr Notebook Deity
    Remove the complete cooling system. And there are 3 screws on the other side of the fan.
