Gt60 NVIDIA Settings are not available. You are not currently using a display attached to an NVIDIA
Discussion in 'MSI' started by panamaniacs2011, Jun 24, 2016.
  1. panamaniacs2011
    panamaniacs2011 Notebook Consultant
    hello!! just got a gt60 (ivy bridge) without gpu , separately i got an msi gtx880m 8gb and i am wondering if is plug and play or do i have to do something extra? thank you in advance
  2. iTzZent
    iTzZent Notebook Consultant
    it´s plug and play. but you need also the kepler heatsink for the GTX880M.
  3. panamaniacs2011
    thanks ... i do have a kepler heatsink but screws dont match the mountng holes on the graphics card bracket , it seems screws are too thick to fit the holes , dont know how to fix this. also could you help me with pad thickness please i dont want to mess up , thank you
  4. Zoltan@zTecpc
    Zoltan@zTecpc Company Representative
    The GPU shouldn't have a bracket only the holes the motherboard has the screw posts.
    Sent from my SAMSUNG-SM-N915A using Tapatalk
  5. mufferer18
    mufferer18 Notebook Consultant
    You must buy screws M2 or M2,5 as I remember, and have some caps to hold the screws with radiator.
  6. panamaniacs2011
    Hello!! got a gt60 , installed an msi gtx 880m 8gb, installed drivers without problems, afterwards without restarting tried to access nvidia control panel and got
    NVIDIA Settings are not available. You are not currently using a display attached to an NVIDIA gpu, then i uninstalled Intel HD drivers, restarted and i have now a black screen, help please!!
    Edit 1 i am able to access bios, i get the black screen as soon i get into Windows, using unlocked bios btw
    Edit 2 Had to remove GPU in order to use the laptop again, next thing im going to try is flashing the card with svl7 vbios, dont know what else could be done :(
    Edit 3 forgot to mention i am using the ivy bridge model
  7. panamaniacs2011
    i managed to install the card but i get a black screen when installing latest nvidia drivers
  8. Kevin@GenTechPC
    Perhaps you will need to flash the VGA BIOS on the graphics card, have you done that already?
  9. zipperi
    zipperi Notebook Evangelist
    I suppose it doesn't work without Intel drivers as Optimus is channeling the signal from Nvidia via Intel to the output jacks (my GT70 0NE).
  10. panamaniacs2011
    So i have to connenct an external monitor to be able to use the gtx880m?
