GT 72s Upgrade Panel
Discussion in 'MSI' started by Danishblunt, Apr 27, 2018.
  1. hacktrix2006
    @senso nice one bud, could you PM the supply info to me please might have a look. Glad you manage to sort it though.
  2. senso
    senso Notebook Evangelist
    hacktrix2006 likes this.
  3. hacktrix2006
  4. Danishblunt
    Danishblunt Guest
    Sweet man! I'm probably going for this as well once i upped to a GTX 1070 or GTX 1060 :)
  5. XMG
    XMG Company Representative
    You're welcome, glad it worked out for you!! Have fun with the bubblewrap ;-)
  6. hacktrix2006
    @senso do you have a link for the cable or part number at least? Might that the plunge in 2 months.
  7. senso
  8. hacktrix2006
    Thanks bud, was the connector placed back the same or did you have to swap the position around?
  9. senso
    On the display side?
    Same side, just swap the cable and route it via the same place, be warned that you need to do a full tear down and remove the mobo due to how the cable is routed.
  10. hacktrix2006
    Thanks sensor, ya I knew about the full tear down part but it's needed anyway. I need to clean the under keyboard side anyway and also check to make sure everything is ok on the mainboard, as well as sort my hinge out as it's getting stuff now. MSI really doesn't do well with hinges.
    Sent from my LLD-L31 using Tapatalk
