GS75 with 240hz panel
Discussion in 'MSI' started by Random42352, Mar 15, 2020.
  1. Random42352
    Random42352 Notebook Geek
    Can anyone with GS75 Stealth 9SE (17 inch) with the 240hz panel tell me which display panel does it use?
    You can see with HWINFO (the program) -> Monitor
    Thanks a lot.
  2. N2ishun
    N2ishun Notebook Consultant
    I've got the GP75 Leopard 9se with a 144 hz display and it's a AU Optronics B173HAN04.0 also known as a AUO409D
    BTW, Aida64 (the program) will also show everything hardware wise in the same detail as HWINFO.
    Kevin@GenTechPC likes this.
  3. Support.3@XOTIC PC
    Support.3@XOTIC PC Company Representative
    Pretty sure they use a SHP14D3, but don't have one on hand to check at the moment.
    --Edit, this is for the 15.6", disregard
  4. Random42352
    I was looking for info about the 17 inch version (GS75)..if you happen to have any, thanks!
  5. Support.3@XOTIC PC
    Should have looked closer, I would have noticed that the sheets looked pasted from the 65. If I can get my hands on the 75 I'll revise.
    Random42352 likes this.
  6. hil
    hil Newbie
    HWiNFO says about my GS75 9SF
    Monitor Name:
    AU Optronics [Unknown Model: AUO509D]
    Monitor Name (Manuf):
    AUO B173HAN05.0
    Kevin@GenTechPC and Random42352 like this.
  7. Random42352
    Thank you!
