GS65 Stealth battery drain under CPU/GPU load
Discussion in 'MSI' started by bogdanp, Jan 30, 2020.
  1. bogdanp
    bogdanp Newbie
    Hello,
    I have a strange problem with my new GS65(bought last week). It's the 2060 one with 180W adapter.
    When I'm playing games, it seems that the battery is slowly discharging(2-4%/hour). - leaving it aside the hot temperatures - managed to get a work-around after reading the topics - disabled cpu boost from windows.
    Last night, while powered off, it lost 4% of it's battery.
    I read many topics in this regard but none about the GS65.
    Do you experience the same problem(is this normal behavior)?
    I bought this laptop because of it's good battery considering this is a gaming laptop, as I do work related stuff on it also.
    Should i return the product?
    Thank you.
  2. Kevin@GenTechPC
    Both are normal behaviors.
    1. Turbo boost using battery power to increase performance.
    2. System consumes power while it's off, not truly off.
    bogdanp likes this.
  3. bogdanp
    bogdanp Newbie
    Thank you for your reply.
    Just to clarify the situation, when I said that I managed to get a workaround, I meant for the hot temperatures, not the battery drain. It still happens witihout turbo boost.
    Kevin@GenTechPC likes this.
  4. senso
    senso Notebook Deity
    Its the MSI Battery Boost, but almost all laptops do that, some battery drain under heavy load, doesn't matter the AC wattage..
    Kevin@GenTechPC and bogdanp like this.
  5. bogdanp
    bogdanp Newbie
    Interesting, I had multiple laptops(either working/gaming ones) and neither of them had this "feature".
    I am wondering if this will affect the battery life in the long run?
  6. Kevin@GenTechPC
    Yes it would since there's tear and wear. If this is a concern you can open up the system and disconnect the battery (while it has 50% charge remaining).
    Otherwise, the battery typically can go through 500-1000 cycles with one-year warranty from the manufacturer.
    bogdanp likes this.
  7. sa7ina
    sa7ina Notebook Consultant
    Is it possible that battery drainage occurs only on windows?
    I'm using mine for deep learning under full load 30 hours at a time and never noticed any drainage.
    Always stays full when connected to the wall.
  8. Kevin@GenTechPC
    There's a mechanism used to detect certain workload and trigger the behavior so perhaps deep learning isn't supported.
    sa7ina likes this.
