Graphics Card upgrade for M6800 ?
Discussion in 'Dell Latitude, Vostro, and Precision' started by derei, Jun 27, 2017.
  1. derei
    derei Notebook Consultant
    Well, I don't think so I will go with P5000, especially that I couldn't find any price for it (only desktop models)... but I'm guessing is at least double the price compared to 980M... Anyway, if you know a place that sells it, I would appreciate a link.
    Thank you for pointing this detail... as it seems, there are A LOT of small quirks to be aware of, in this upgrade...
  2. Aaron44126
    Aaron44126 Notebook Prophet
    Did you try using a Pascal GPU in the M6700, with Optimus enabled? It seems like if Optimus is on, it shouldn't matter if the card requires eDP, as the display output is handled by the iGPU.
    I've only heard from one other person who has tried this, and he told me that he was not able to fit a GeForce 1060 in the M6700 because of issues with fitting it to the heatsink properly, so he was not even able to try it .....
  3. iieeann
    iieeann Notebook Evangelist
    Yes i tried it, but i did not do fresh OS installation. I just plug in existing OS with UEFI, secure boot off, legacy boot off. There is display of Dell logo, can go into bios, but no more after that. Just stuck at Dell logo, no prompt of unable to find bootable media. I did not try further because my CPU heatsink screw hole thread has damaged after frequent dismantling and i have to use a custom longer screw to secure it. M6700 design is bad for GPU replacement since CPU heatsink needs to be removed before GPU heatsink, M6800 has improved the design by reversing this sequence.
    I am getting every small parts of M6800 to assemble into a working laptop, eDP, now still waiting for some parts to arrive should complete in next 3 days. Will install new OS on it hopefully it will work.
  4. sicily428
    sicily428 Donuts!! :)
    here some part numbers
    Fujitsu
    P3000
    CP730093-XX 34061683
    P4000
    CP730092-XX 34061682
    P5000
    CP730091-XX 34061681
    Lenovo
    M620
    01AV356 N MXM,N17M-Q3,Bitland
    P3000
    01AV355 N MXM,N17E-Q1-A1,NVIDIA
    P4000
    01AV354 N MXM,N17E-Q3-A1,NVIDIA
    P5000
    01AV353 N MXM,N17E-Q5-A1,NVIDIA
    Dell
    P3000
    [490-BDKG][490-BDKH] / P3000
    P4000
    [490-BDKF][490-BDKG] / P4000
    P5000
    [490-BDKG][490-BDKK] / P5000
    HP
    M1200
    Part No: 917108-001 Description: SPS-GFX NVIDIA Quadro M1200 4GB
    M2200
    Part No: 917109-001 Description: SPS-GFX NVIDIA Quadro M2200 4GB
    P3000 Y3J90AV
    Part No: 917110-001 Description: SPS-GFX NVIDIA Quadro P3000 6GB
    P4000
    Part No: 917111-001 Description: SPS-GFX NVIDIA Quadro P4000 8GB
    P5000
    Part No: 917112-001 Description: SPS-GFX NVIDIA Quadro P5000 16GB
    RMSMajestic and derei like this.
  5. mitchellpeixer
    mitchellpeixer Notebook Enthusiast
    any chances to fit a 1060 on m6800? :vbconfused:
  6. Aaron44126
    The GeForce 1060 requires eDP, so you will have to make sure that you have an eDP model M6800 and not an LVDS one. Otherwise, it could possibly fit if you find a standard sized GeFrorce 1060 MXM card (these aren't hard to come by). As for whether it will actually work, I haven't heard of anyone who has tried it yet...
  7. ijozic
    ijozic Notebook Deity
    Yeah, but perhaps the Optimus support also needs to be enabled in the vBIOS and it might not be there by default?
  8. Aaron44126
    I suppose it's possible that there are vBIOS variants that do not have Optimus support, but I know the 1060 and 1070 do support Optimus (It's out there on other systems). In any case, it seems like the system should be able to boot, and if the card does not support Optimus, it will just error out in device manager. @iieeann says that it hung at the Dell logo during POST... so there must be something in the Dell BIOS that disagrees with at least the card that he tried.
  9. ijozic
    P5000? Nice, Looking forward to see how it works on the M6800. Where did you get it and how much it went for, if it's not a problem? I have an M6700 with the eDP screen so I'm definitely considering one as a future upgrade if they can be found for a reasonable price.
    The 7720 doesn't have Optimus (right?) so there's no need for its support in the Dell P5000 vBIOS, I'd presume. Since the physical designs are different, not sure if it could be flashed with e.g. an Alienware 1070 vBIOS.
  10. Aaron44126
    7
    7720 does have Optimus, but you can switch it off in the BIOS of you so choose. I'm sure that Dell's P5000 supports Optimus.
