Graphics Card upgrade for M6800 ?
Discussion in 'Dell Latitude, Vostro, and Precision' started by derei, Jun 27, 2017.
  1. iieeann
    iieeann Notebook Evangelist
    Using nvflash.
    DynamiteZerg and sicily428 like this.
  2. DynamiteZerg
    DynamiteZerg Notebook Evangelist
    Thanks! I'll try my luck at getting a P5000 that doesn't cost me an arm and a leg... just maybe a hand... :p
    Which version of nvflash specifically? I remember each gen Kepler, Maxwell and I believe Pascal as well should have different versions of nvflash that works for them.
  3. supermoth
    supermoth Notebook Consultant
    Could you confirm if the upgrade was done to an LVDS motherboard or an EDP?
    ThAnks for sharing
  4. Aaron44126
    Aaron44126 Notebook Prophet
    Pascal only supports eDP. If it works with the M6700, it will require either Optimus enabled or the IPS display.
  5. iieeann
    Just the latest one, version not remembered. Works only under windows command prompt, not under pure dos environment. Use admin.
    nvflash64 --list
    See what index number is listed, i.e. <0>
    nvflash64 --index=0 -6 ROM_NAME.rom
    If not using Optimus, the screen may go blank during flash and you won't see the prompt to press "Y" to continue. In this case u have to press Y in blank.
  6. DynamiteZerg
    Can you point us to a link to the latest version? Or is it possible to upload it here?
    I did a search in the NBR forums and found the link below:
    https://www.techpowerup.com/download/nvidia-nvflash/
    NVIDIA NVFlash 5.449.0
    April 27th, 2018
    Can you check if your version is similar? I just secured my own P5000! So can't wait for it to arrive and install in my M6800 to replace my GTX980M! :)
    supermoth likes this.
  7. xm7
    xm7 Newbie
    Do we know if Pascal runs on both eDP port versions? AFAIK there is newer 30pin and older 50pin, does it make any difference?
  8. supermoth
    Those are great news.
    Could you tell us where did you source the card from?
    Also could you create a tutorial ?
    Thanks
  9. DynamiteZerg
    @Aaron44126 do you have an idea?
  10. DynamiteZerg
    I managed to snipe one from fleabay by using the "Best Offer: Make Offer" option. The price offered by the seller was already quite alright and I just tried to see how low the seller is willing to go.
    What tutorial are you talking about?
