GPU Always Hit Power Limit (MX150 1D12)
Discussion in 'Gaming (Software and Graphics Cards)' started by re23071998, Jan 3, 2019.
  1. re23071998
    re23071998 Notebook Enthusiast
    Hi,
    right now I'm using this Lenovo IdeaPad 320s-13ikb.
    the GPU always hitting power limit according to MSI Afterburner monitoring and the GPU clock going down to ~800mhz, base clock should be 937mhz.
    temps are good, about 60-65°c (stable at 60).
    I guess the problem is the AC adapter? it's 65w adapter I believe, should be enough for 8250u + 10w mx150.
    or maybe Lenovo set them lower with the bios?
    any thoughts?
    thanks!
  2. DRevan
    DRevan Notebook Virtuoso
    Lenovo set the tdp in the vbios too low.
    Nothin can be done, because even if the vbios is not built in the system bios, you still need an spi programmer to flash a modded vbios with higher tdp.
