GPS issue-- CF31 Mk5
Discussion in 'Panasonic' started by cleatus, Sep 19, 2017.
  1. cleatus
    cleatus Notebook Enthusiast
    watching the gps data stream its showing GPRMC..V...........N*53
    keeps repeating (amongst the rest of the data and 99,99,99;s...)
  2. cleatus
    just reimaged one of the "bad" laptops--no fix. looking like hardware....
  3. SHEEPMAN!
    SHEEPMAN! Freelance
    Could it be antennas, cables , dock or the pass-through? Dual pass-through hooked up to the wrong antenna? (wires crossed)
    Test the GPS with a USB antenna while not docked?
    Test with WWAN disabled and un-docked?
    I (meaning this is what I would do) would run a liveusb through it for diagnostics.
    Code:
    lsusb
    dmesg | grep input
    dmesg | grep  Qualcomm -i ##maybe Sierra or Gobi
    dmesg | grep pl2303 -i
    Just to compare with a working one.
    Right now I suspect antenna and/or cables.
  4. cleatus
    it is not docked- so no pass thru issue-
    pulled the cover off the antenna--no "obvious" issue, but no way to manually test it.
  5. SHEEPMAN!
    SHEEPMAN! Freelance
    PL2303 serial usb driver won't show on many Linux OS's. Blacklist by default.
    USB antenna should load a serial/usb driver when hot-plugged.
    But it's as you say, probably hardware.
  6. cleatus
    this is Win 7 64.
    its so odd as there dosnet seem to be a trigger-- they just stop working.
  7. SHEEPMAN!
    SHEEPMAN! Freelance
    Sorry not enough coffee.
    Forget the USB antenna.....
    Can you pull the bottom cover or are there warranty issues?
  8. cleatus
    can prob pull-- I did find a video on installing a gps module. maybe could have a look.
    don't think its shock or bumping around that's breaking it --- I have one Toughbook that sits at my desk--- now that one stopped working.
  9. SHEEPMAN!
    SHEEPMAN! Freelance
    Just to see the layout.
    Whether lid antenna goes direct to gps or to a passthrough and then jumpered.
    And if the bottom fell off of one accidently you could attach a spare antenna direct to gps device and just throw it on the desk for test purposes.
    Hmmmm, I wonder if the machines were spec-ed with a gps battery. Visible through the ram door on a MK2. Antenna not visible. END EDIT
    LEFT IS GPS BATTERY ATTACH POINT ...RIGHT IS FPC/MOBO CONNECTOR
  10. cleatus
    wow....do I feel like an idiot....time to eat crow.
    Not saying its the entire issue, as I have had to send back a couple that the users said were not working...buuuuuuuuuuuuuuuut.....
    It turns out they had all the windows here at work tinted...apparently with security/metallic tint....FFS...
    They used to work in my office if I put them in the window, they would get a good GPS fix. Not so much now...lol....FAIL.
    If I walk outside in the -3 deg weather, it will get a signal in about 1 min. When I bring it back in, the signal drops to nothing.
    All this time I have been looking for a "tech fix", when it looks like it was something as stupid as window tint.
    Wow.o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
    Thanks to all that have helped.
    I am going to go be an idiot in the corner...
    toughasnails and SHEEPMAN! like this.
