GPS issue-- CF31 Mk5
Discussion in 'Panasonic' started by cleatus, Sep 19, 2017.
  1. cleatus
    cleatus Notebook Enthusiast
    Not sure where the issue lies....
    updating out fleet of squad laptops--windows updates, Java update, and Malwarebytes update.
    Users reporting GPS not working.
    They all seem to be users on the Sierra wireless NMEA GPS--Panasonic internal (so far) seems to be working still
    when we got these laptops new, I have to do that UBX (dos screen) command to get them to output NMEA strings. It would go thru steps 1-5 and finish/start working as needed
    some of these dead ones I try to run the DOS command and it hangs on step 1 fro about 1 min then errors. it will continue, and look like it re-trys step 1-5 and I shows it completes.
    after all that, its showing GPS signal, but seems to look different than what it should, and it doesn't find any satellites
    I am wondering if the internal GPS isn't jacked, and if there was a "factory reset" I could do on it?
    any other help would be great!
    (of course time is critical-- we have many computers that are down because of this)
    thanks!!!!
  2. cleatus
    think the latest MS defender definition killing it...looking into it more
  3. Shawn
    How come some have Panasonic real gps and others have Sierra?
  4. cleatus
    internal gps option that came with the laptop, and internal optional sierra wireless GPS/Verizon card
    (as far as I can tell) :)
    they have both
    so far, with testing, it appears Malwarebytes update and java update do not affect the sierra wireless NMEA port--
  5. Shawn
    So if they all have both, why not just use the real Panasonic gps and forget the Sierra?
  6. cleatus
    some of the Panasonic GPS's are "messed up"-- caused by me....back before we discovered /dos fix thing.
    that's why I was looking to see if there was a "reset" string we could run on the internal gps to reset it back to factory
  7. SHEEPMAN!
    SHEEPMAN! Freelance
    Are they Leadtek or something else?
    The three uninstalled ones that I have here are all Leadtek.
    If they were for instance Ublox, then U-center has tools for factory reset.
    There are warnings that communicating with some GPS units can break them.* So use the right tool for the job would be my advise.
    *Here is a gpsd html with a lot of links.
    http://www.catb.org/gpsd/hall-of-shame.html
  8. Shawn
    mk5 should be ublox.
  9. cleatus
    pretty sure ublox.
    had to run that gps/ublox/dos thing to get it to output GPRMC (apparently what we need)
    now it wont re-flash and seems to show data coming in to the gps, but never gets a location
  10. cleatus
    well-- im back to this again...GPS's not working. here and there.
    tried the GPS viewer- It shows data coming in (lots of 99,99,99,99,99's mixed in there.)
    it will pop up about 5-10 satellites on the screen for about 1 second, then disappear for about 5 seconds (repeat)--
    never gets location, shows ZERO sats in use, and Status: Invalid
    I have been sending these things in for "repair" and they put in new GPS modules...so far most have come back, I run the UBX thing on them to get NMEA, and they work.....buuuuuuuuuut, I got one back yesterday, and it was not cooperating.
    I reaaaly need to find out what's going on.
