GoshDARNIT!!!! Can you help me uninstall UT3?!
Discussion in 'Gaming (Software and Graphics Cards)' started by Sherman90, Nov 23, 2007.
  1. Sherman90
    Sherman90 Notebook Consultant
    I wanted to reinstall UT3, so I ran CCleaner and uninstalled my initial copy. So far so good...
    I've been trying now to run the setup.exe from the UT3 disc and no matter what I do I keep getting the same error. Firstly, there is no option to install...ony to uninstall and to launch. Launching fails, of course, and when I try to uninstall, I get the errir "1628: Failed to complete installation".
    Windows uninstaller still lists Unreal Tournament 3 and cannot uninstall it.
    When I try to force the setup directly, UT3 first tries to uninstall and fails...
    I deleted all my temporary files, scowered my registry and deleted the only UT3 entry I could find (not sure if there are more), deleted all of the UT3 folders I could find...and still no dice!
    Could anyone lend a hand??
  2. DeusEx
    DeusEx Notebook Evangelist
    well if you got no options left then reformat the hdd... other than that i cant give any useful advice.
  3. Sherman90
    nm
    I used system restore...uninstalled successfully using the CD uninstaller :)
  4. TechnoWhore
    TechnoWhore Notebook Consultant
    I usually get that if there is registery left over from a bad uninstall. I find a proper uninstaller like "Your uninstaller" and a good registery cleaner like "TuneUp utilities" gets rid of these errors. Manually you can delete the whole register folder for UT3 manually (regedit, or maybe CCleaner has a reg editer?) to make the computer stop thinking it has the program installed when it isn't. Hope this helps a bit.
  5. dmacfour
    dmacfour Are you aware...
