GL553VD RGB KEYBOARD ISSUE
Discussion in 'ASUS Gaming Notebook Forum' started by mmohamed2, May 26, 2018.
  1. mmohamed2
    mmohamed2 Newbie
    Hi,
    I have ASUS ROG GL553VD
    I changed the color of the keyboad to white but the 2 right parts looks yellow
    CHECK THE IMAGES
    UPDATE
    someone have the same issue
    after i tried multiple colors, now, i have 3 right parts yellow
    Note: all colors are not right, only rgb colors(red,green,blue)
    i literly tried every easy software solution, installing fresh windows,trying mutiple bios versions,aura core versions,ATK package... nothing work, something need to reset to remove the stuck color,
    do you think removing cmos battery will fix the issue? because i think the colors registered there
