GL502VS Loose LCD Panel/Bezel
Discussion in 'ASUS Gaming Notebook Forum' started by prinzhernan, May 11, 2017.
Tags:
  1. prinzhernan
    prinzhernan Notebook Enthusiast
    Hi guys. Well I just got my GL502VS and I noticed that on the lower left, the sticker which glues the frame to the LCD itself isn't so strong? There's a small gap and if you look really well you could see the led lights inside. It doesn't really affect normal operation but I was wondering if you guys also experienced the same thing? I really don't want to return it since I'm on the road and busy. Will this eventually be a problem in the years to come or is it fine if I leave it like that. I'm pretty happy with the laptop but the problem is this is the last piece the store had when I bought it and it's kinda hard to find this model in my country. Thanks!
