Gigabyte P35W V3 Owners thoughts
Discussion in 'Gigabyte and Aorus' started by slikvik, Jan 2, 2015.
  1. Xss
    Xss Notebook Consultant
    Hello,
    I am currently debating between either taking the P34W or the P35W V3. Two quick questions: how is the heat/throttling on this machine? Secondly, are the CPU/GPU soldered or are they upgradeable? Thanks!
  2. markjk7
    markjk7 Notebook Guru
    I own the P35w v3 so only know about that, but I'm 99% sure the CPU/GPU are not upgradeable. Heat/Throttling I've never had an issue with and the new BIOS (which I haven't used yet) I believe sets the max temp to 95deg so I would think would remove the very minor throttling that you could get running benchmarks before (90deg). The key is fan noise though really as running on full Max fans removes any throttling but is very loud. I actually run the CPU under-volted and under clocked to 2.4ghz most of the time and i can then play most games with the laptop on my knee and on the 'low auto' fan profile and whilst my better half is watching TV :)
    I'm very happy with mine, it's great for my needs, but I know there are a few who have had issues more so with the p35x version so maybe worth having a read in that thread. Also quite a lot of choice in the 15" 970m laptops now so choosing got much more difficult... Hope it helps.
  3. Xss
    Yes, GentechPC just confirmed to me it is not upgradeable: bummer!...Oh well. Anyway, thanks for your feedback! :) I'll go have a look at the P35X thread, but what are the biggest issues people are having (apart from the 970m suddenly disappearing)?
  4. bernieyee
    bernieyee Notebook Evangelist
    If the laptop has a HQ processor, it's soldered. If it has a MQ, it's socketable and removable.
  5. Xss
    Well, I've finally ordered mine from GenTechPC: we'll see how it goes! :)
  6. blac
    blac Newbie
    hi,any update on disconnect graphic card issue?since i also having the same problem..update to new bios and some update also not helping
  7. Xss
    Boy, I had totally forgotten about that issue, I hope I won't run into the same problem :/
  8. Xss
    Well, I have just received my P35W, out of the box, factory installation and...No 970M...Great, I either find a solution or I am asking for a refund.
  9. markjk7
    Sorry to hear that, is it not showing in device manager or gpuz?
  10. Xss
    Not at all.
