Gigabyte build quality and warranty questions
Discussion in 'Gigabyte and Aorus' started by RockyBalboa-UK, May 17, 2017.
  1. don_svetlio
    I believe they applied pressure to the sides and centre. As a result, the casing around the ports on one side cracked. And honestly, it doesn't surprise me - it's the same thing as Asus' UX501/G501 machines. The aluminium used is quite thin and bends without much force required. As a result, when you push it a bit harder, it can crack and break. That's what I really like about Apple's unibody designs, they are incredibly durable considering the slim profile.
  2. Support.2@XOTIC PC
    Makes me miss the old thicker aluminum panels that would just deform and then never bend back quite exactly right from previous generations.
    don_svetlio likes this.
  3. don_svetlio
    But those were also much harder to bend and twist in the first place ;)
  4. Support.2@XOTIC PC
    Yeah, and were heavier. I think the best solution would be some sort of composite/plastic.
  5. don_svetlio
    Or, you know, charge 2000$ for entry-level with macbook-like chassis :D
  6. Support.2@XOTIC PC
    Once you start down the dark path, forever will it dominate your destiny, consume you it will.
    agent_pires and don_svetlio like this.
  7. asm1
    asm1 Notebook Evangelist
    well my P34w V3 drama has got me to the point where I am seriously thinking of 'writing off' the laptop. It has made me a bit wary of 14" laptops....:(
