Getac B300 G5 Phoenix Bios problem
Discussion in 'Other Manufacturers' started by Mraz, Dec 5, 2018.
  1. Mraz
    Mraz Notebook Enthusiast
    Hello, today I've decided to remove my password to bios and change settings. At startup, I pressed the F2 key and entered the password. Everything was going on normally. In the Security menu, I entered the password again, then left the lines blank and pressed the enter key twice. So I removed the old password. Then I moved to the Boot menu and wanted to enable USB ODD that was disabled. I have reached the appropriate line and pressed Shift + 1 keys. But nothing happened, I tried it several times, without any results. I tried to change other lines, but nothing could change. I thought if it had anything to do with a password, so I moved back to the Security menu and tried to enter the password again. After filling in the first line, I realized that I was entering a new password, so I pressed the ESC to interrupt it. It occurred to me that maybe before changing the settings (after deleting the old password), I need to restart the laptop and re-enter in the bios. I pressed the F10 key and saved the settings. After the restart, a password was required to access bios (I do not understand why when I removed it), I tried to enter my old password, but it did not work.
    Can you help me ?
  2. t456
    Hit 'enter' when it's requesting the password, don't type in any characters.
    There's a difference in how it behaves between never-password and once-but-now-removed-password. If you want the old no-request behaviour back you could try flashing an older or newer version after you've cleared it in the security page.
  3. Mraz
    Thanks for the information, I will try to flash bios
  4. Mraz
    So I made a bios flash but still requires a password (old password does not work). :(
  5. t456
    It's not blank then? So just hitting 'Enter' isn't enough?
    A password will survive a flash, but usually it won't even let you flash a new bios version unless you provide the password. You did flash a newer or older version, right? A same-version bios will likely be skipped without flashing at all.
  6. Mraz
    I did flash a newer version. The old version was version is: R1.03.170502 new is :R3.01.010600 (Phoenix Bios). Only the latest version is available on the manufacturer's page, I can not try older :(
  7. Mraz
    I searched a bit on the Internet and found out that someone else had created an unknown password for access to the bios in a similar way as I do.
    The symptoms are the same, entered the bios password, tried to change the settings (which was not possible), then remove the password. After saving and restarting a password was required, the old password does not work. It was also Phoenix Bios, but I do not know the version.
