Genuine or Aftermarket Battery
Discussion in 'Lenovo' started by claudehl, Feb 19, 2013.
  1. claudehl
    claudehl Notebook Geek
    Hello:
    I would like to purchase a replacement battery for my Lenovo T520 notebook. Are there any quality differences between the inexpensive aftermarket batteries vs the more expensive Lenovo brand batteries? Is this is a case where you get what you paid for?
    Thanks,
    C.
  2. ajkula66
    ajkula66 Courage and Consequence
    In my not-so-modest experience, yes.
    Genuine batteries can be found on both feebay and Lenovo's outlet, the latter might test your patience, though.
    Happy shopping.
  3. Jarhead
    Jarhead 恋の♡アカサタナ
    OEM batteries, while expensive, are pretty much going to work 100% of the time. Aftermarket batteries, while cheaper, can be a hit or miss (several variables go into that). Some aftermarket sellers have good batteries, some have okay batteries, and some are crap.
  4. diggy
    diggy Notebook Deity
    We order our replacement batteries from laptopcharge.com and have never had any problems with them
  5. MidnightSun
    MidnightSun Emodicon
    You'll need to do your research to find a reliable aftermarket battery supplier for Thinkpads (I know ZaZ had a favorable experience with one). I think Power Manager will give you intermittent nag messages of "non-genuine" battery status every once in a while as well, but that's a more minor concern.
  6. Flickster
    Flickster Notebook Evangelist
    Like the others mentioned. OEM batteries are one of the safest ways to go, you can often buy from a OEM battery supplier for a lower price than the official outlet.
    Like most products, you normally get what you pay for. That is not to say that the most expensive is always best but if your comparing a product from reputable suppliers and the price difference is substantial, you can safely assume there is a quality difference. When talking batteries that normally comes down to the type and quality of cells used in the battery. Higher capacity (mAh) cells from reputable manufacturers i.e. Samsung, LG etc simply cost more, naturally this mean the products that use them are more expensive.
  7. MaX PL
    MaX PL Notebook Deity
    nice thread. i'm in the market for a new 9 cell for my T400 as well. i still get 6 to 7 hours on the currenty one after 4.5 years, but i want it back at 11 to 12 hours.
    will probably go for a new oem one for ~$90 on ebay as lenovo epp sells em for $140 i believe.
    still need help finding a new AC adapter though. none of the ones on lenovos website specify which computer theyre used for.
  8. ajkula66
    Well, you need a 20V/90W adapter...the same one used on all ThinkPads with discrete graphics since *60 series.
    Expect to pay $20 for a genuine one on feebay or TPF's Marketplace, presuming you're in the U.S.
  9. MaX PL
    yeh the current one i have is a 20v/90w yet my moms T400 that she has from work, that one uses a smaller one thats 60w i believe(not 100% on this).
    i'm assuming thats because her model is integrated gfx only, and since I only use the integrated on my T400, could I just use an adapter like hers?
    edit: ok so i guess this is her adapter:
    http://shop.lenovo.com/SEUILibrary/...tem.detail?GroupID=460&Code=40Y7696#techspecs
    its 65w and the only one listed when i search for T400 accessories.
    anyone know if this can be used if i'm only on integrated?
  10. MaX PL
    oh, completely forgot. i actually bought an aftermarket 90w off ebay a few weeks back, but had to return it since the cables were half the length of the oem one. disappointing considering it only cost me $10.
    the only oem ones i can find on ebay are used.
